Where exactly to tap on an ATS manifold
Old May 5, 2004 | 10:17 PM
Cowhand's Avatar
One would think the answer is obvious, but I, like a few others, thought that the center section came tapped for a pyro already.
I'm thinking roughly half way between the flanges, between #3 exhaust port and turbo.
Am I screwed up as a football bat?
Old May 5, 2004 | 11:47 PM
infidel's Avatar
Every ATS I've dealt with has a round raised area where you drill/tap. Same location as on a stock manifold.
Old May 6, 2004 | 11:06 AM
RowJ's Avatar
Curious
Why is whole off center towards rear of block??
Old May 6, 2004 | 12:47 PM
phox_mulder's Avatar
Re: Curious
Consensus is that #6 runs the hottest, so you want to monitor it's output.
Also, there is a divider/support inside the manifold dead center, and you don't want to drill into that.
phox
Old May 6, 2004 | 12:52 PM
RowJ's Avatar
Suspected it might have to do with better reading on #6.
Old May 6, 2004 | 03:54 PM
Cowhand's Avatar
Thanks guys. I was under the mistaken impression that #1 ran hotter. Now if I can just find time to put my goodies in......
Old May 6, 2004 | 04:20 PM
I've heard that lately as well.
Someone here (Dieseldude4x4?) recently melted his #1 piston, or something like that.
Maybe it was Haulin_in_Dixie?
All I know is, as long as I've been here, they all say to tap that side of the manifold.
phox
Old May 6, 2004 | 05:32 PM
HOHN's Avatar
Check my reader's rigs for a pic of the probe location
HOHN
Old May 6, 2004 | 05:52 PM
infidel's Avatar
For what it's worth, Piers says #1 is hotter on 24 valves, #6 on 12s
Old May 7, 2004 | 12:34 PM
RowJ's Avatar
Suprising
Of the few (very few) 24v engines I have heard of that fried themselves, all discussed most damage done to #6 piston.
Old May 7, 2004 | 03:31 PM
banshee's Avatar
I've heard the opposite of that. The 12V head has casting in the #1 intake port that hurts its flow. he EGTs are normally a little higher up front for that reason. Like RJohnson, every 24V I have seen burnt up had the #6 cylinder toasted.
Old May 7, 2004 | 03:41 PM
BigBlue's Avatar
Easy solution. Put a probe in both locations and take the average. That should give you a good idea of where your temp should be.
Old May 7, 2004 | 03:57 PM
Cowhand's Avatar
You guys are confusing me
I just got off the phone with Mark@PDR, he says #6 is hottest on the 12v....
Old May 7, 2004 | 04:12 PM
banshee's Avatar
Not saying PDR is wrong, but this is an old post from testing on the Banks Twin Ram. He showed #1 to be the hottest.
http://www.turbodieselregister.com/f...light=twin+ram
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
staarma
Apr 17, 2008 06:29 PM
Hoss
Apr 11, 2006 11:37 PM
bgilbert
Mar 2, 2006 04:01 PM
