Eratic Mpg, Miss At Idle, Choking Downhill
Old 05-29-2008, 12:49 PM
qmlogan's Avatar
I Haven't Had My Truck Long, But The Mpg Are Eratic( 10,13,15,17 ). Also I Have A Miss At Idle That Comes And Goes, But Doesn't Do It All The Time, And Finally I Sometimes Get A Loss Of Power Or Choke Feeling When I Let Off The Accelator Going Downhill. Is This Injector Problems? Any Help Would Be Appreciated. Thanks
Old 05-29-2008, 02:01 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Maybe injector issue, suggest having check for codes at Dodge dealership. Pull your fuel filter and check for contamination such as water or rust before taking in. If contamination is found by dealer may void warranty. Good Luck
Old 05-29-2008, 02:18 PM
Hounddog's Avatar
Maybe Fuel Control Actuator or more commonly called a FCA.Use the SEARCH function on FCA.Meanwhile add a big slug of ashless two stroke oil like two cans or some of the more popular diesel lube and fuel treatment to your fuel.If problem goes away and returns after refueling and NO additive its a bad FCA.
Old 05-29-2008, 08:10 PM
Cummins Guru
BigIron70's Avatar
Didn't notice 176K miles your out of warranty, I wouldn't worry about down hills it would be up hills I would worry about. Do you have an exhaust brake?
Old 05-30-2008, 04:02 PM
qmlogan's Avatar
no codes. no exhaust brake. I will try fuel treament and check fca.
Old 05-30-2008, 11:11 PM
Cummins Guru
BigIron70's Avatar
Fca
Here is procedure to check FCA. Hope this helps.
Old 06-02-2008, 08:13 AM
2006Mega's Avatar
could you have a crack in a fuel line allowing air into the system?
countrygent
06-03-2010 08:13 AM
titan1
54
04-12-2009 10:40 AM
dieselguy71
01-28-2009 11:02 AM
bigbaddiesel
03-18-2003 02:37 AM
Quick Reply: Eratic Mpg, Miss At Idle, Choking Downhill
