Enough Fuel???
Old Dec 27, 2006 | 09:10 PM
ct2500's Avatar
Enough Fuel???
I have the FASS 95 GPH fuel system will it be able to keep up if I put 150HP Nozzels in.also ive been reading about people that have 95/150 FASS systems How would i know if that is the one that i have.
Thanx Scott
Old Dec 27, 2006 | 09:54 PM
dieselrob's Avatar
yes it will put out enough fuel. Do you have a big line kit? What i mean is 1/2 inch fuel lines. They will help out but any pump better than a stocker will be enough fuel.
Old Dec 27, 2006 | 09:56 PM
ct2500's Avatar
Ive got the 3/8 push-lock
Old Dec 27, 2006 | 10:09 PM
aggiehorsepower's Avatar
I have got the 150 gph and I love it. !8 psi at idle and doesn't drop below 15 wot
Old Dec 27, 2006 | 10:11 PM
dieselrob's Avatar
Is it the stock hard line? The stock line is 3/8 O. D. i think. I ran stock lines with a holley blue and stock pump with a edge comp and 100hp injectors on an 01 with no problems. As long as you can have 10lbs of fuel psi at wot your fine till you start gettin into the 550+ hp zone it seems. My 99 would go dry with 200 hp injectors and edge comp when it had stock hard lines. But after i put half inch lines on it would run till the turbo would be hurting. The 01 has 3/8 line and amd less mods and runs great with 18lbs of fuel psi.
Old Dec 27, 2006 | 10:13 PM
ct2500's Avatar
iam runnin 14psi idle and 12 WOT
Boatnik
Aug 5, 2007 09:09 PM
boiler-rat
Sep 5, 2005 12:59 PM
MOAGGIE
Jul 12, 2005 07:50 PM
DZLPWR
Mar 8, 2005 09:27 AM
jiMMyCTD
Jul 12, 2004 03:52 PM
