Engine sound
Old 01-28-2008, 03:22 PM
07MCummer's Avatar
Engine sound
Hey guys i just put my Smarty on the other day and before i had the Predator Puck stack. I still have the puck on with the smarty. Well i was driving it today and it seemed like when i gave it some gas, not full throttle, but the turbo pitch would change from being a little loud than it would soften then get loud again and it would keep doing it. But when i was at a steady speed it would stop and just sound normal. Any ideas on what this could be would be great because i never had this problem before and hope something is not going bad.
Old 01-28-2008, 03:40 PM
Speed Shift's Avatar
Do you have a boost guage?
Old 01-28-2008, 04:00 PM
07MCummer's Avatar
I do but i was not paying attention to it cause i was trying to figure out what was going on with the sound.
Old 01-28-2008, 04:29 PM
See if you can do it again and see if your boost fluctuates with the sound. It might be the wastegate.
Old 01-28-2008, 05:28 PM
07MCummer's Avatar
I just took my truck out and the boost gauge does fluctuate with the sound. This doesnt mean my turbo is going bad does it? Cause on my other truck that i had it had similar problems and ended up needing a new turbo. Really need some help with this!
Old 01-28-2008, 05:44 PM
Nah, that is just the wastegate doing its job. What is the max boost you see?
Old 01-28-2008, 07:40 PM
07MCummer's Avatar
It is usually between 35 and 40. Dont think i have seen it go past 40. Is there anyway to fix this?
Old 01-28-2008, 07:56 PM
mike moore's Avatar
engine sound
Mine does it to,just the wastegate trying to find a happy spot.
Old 01-28-2008, 08:18 PM
You dont want over 40lbs on a stock turbo, but if you really want you can get a boost fooler and let the turbo buld as much boost as it can.
Everything sounds fine.
Old 01-28-2008, 08:21 PM
07MCummer's Avatar
Alright thanks for all your help! Probably will just load up the aftermarket turbo program on the smarty for the boost fooler.
samiam4
12-19-2012 12:08 PM
OT-OF-Here
26
08-26-2004 11:29 PM
TE-44
01-02-2004 08:34 PM
Rocket95
05-19-2003 10:34 AM
Quick Reply: Engine sound
