Electric fan motor only works on High
Old 10-12-2009, 10:40 PM
chainzaw's Avatar
I disconnected the wire connectors at the motor. Put volt meter on the wires. I only get 12VDC when the dial is on high. 0VDC on any other setting. I pulled the dash apart and looked at the speed dial. It looks more like a switch with several wires coming off of it than a motor controller. Does anybody have a wiring diagram they can post? Any ideas? I tried the search with no luck.
Old 10-13-2009, 12:11 AM
biododge1's Avatar
That is a classic sign of bad fan resistor pack
Old 10-13-2009, 12:12 AM
nickg's Avatar
blower resistor is more than likely shot, heater switch controls the GROUND side of the fan motor (at least according to my repair manual)
blower resistor is located down near fan motor, unplug connector then remove resistor block, windings/coils can be checked with a multi meter, (should have no opens) have heard reports of guys soldering broken wire and having it work, another thing to note, sometime a failing (high amp draw)fan motor can burnout the blower resistor.
Old 10-13-2009, 06:20 PM
old 300's Avatar
As stated by nickg and biododge1 its usually the resistor. Mine went out in August but I only lost low speed. They tell me that is very rare, usually you only have high speed. I my case when I removed the resistor it was cracked and looked like it was wet because it was rusty and turning green.
Old 10-13-2009, 09:40 PM
chainzaw's Avatar
thanks for the advice. i'll take a look tomorrow
Old 10-13-2009, 10:26 PM
johnh's Avatar
be forewarned... the biggest cause of resistor failure is the bearings in the motor are going out....i replaced two resistors before i replaced the motor... the bearings bind up and cause the motor to not rotate as it should, in turn causing the resistor to over heat and burn out
Old 10-14-2009, 12:19 AM
chainzaw's Avatar
How noticeable is it if the motor bearings are shot? If I drop the fan down out of the housing do you think I can tell if it needs to be replaced or not?
Old 10-14-2009, 07:46 AM
johnh's Avatar
i could tell on mine, didn't spin easy
Diesel Girl
18
10-06-2013 03:03 PM
Diesel- Dummy
01-19-2008 12:35 PM
HappyGA
04-30-2006 08:47 AM
hemertwv
09-16-2005 12:12 PM
IntakeRacing
01-09-2005 06:27 PM
Quick Reply: Electric fan motor only works on High
