Electric Fan Kits
Old 03-16-2006, 05:08 PM
Rambunctious1's Avatar
Electric Fan Kits
Does anybody know if there are electric fan kits for our trucks? Preferably one that is controlled by the thermostat. I did a search for this topic and only found info for 1st and 2nd gens. Thanks in advance.
Old 03-16-2006, 05:49 PM
Dodgezilla's Avatar
The problem is in finding one that will fit between the grill and the radiator/condenser/Intercooler combo. Not much room to play with.....
Old 03-16-2006, 05:52 PM
Geico266's Avatar
What's wrong with the stock fan set up?
Old 03-17-2006, 04:40 AM
Dodgezilla's Avatar
I would like one of you electrical gurus to tell me how to wire a toggle switch in line to turn the fan on at will instead of having to turn the A/C on. That fan works better than any electric fan I have ever run......
Old 03-17-2006, 09:09 AM
Actually, I asked this question for a buddy of mine. He's been pestering me to ask the question on here.
Old 03-17-2006, 09:12 AM
Top's Younger Twin
Scotty's Avatar
Dee Rawson out of Utah had two fans on his 2 gen.
I think he had one on the front and one on the back side drawing air. Thats pretty much all I know on it.
Scotty
Old 03-17-2006, 09:24 AM
RustyJC's Avatar
If you work the engine hard (e.g., tow heavy in hot weather and hilly terrain), keep this in mind.
On a former truck, I bought the Flex-a-Lite 350 dual puller setup that eliminated the engine-driven fan. These fans drew 50 amps. 50 amps x 12 volts = 600 watts = 0.8 horsepower. Compare this to the 5-20 horsepower (depending on whose testing you believe) consumed by the engine-driven fan.
My $450 lesson - there's no way 0.8 horsepower can move enough air to handle the heat rejection of an engine that's working hard. On the other hand, it can cool a mall cruiser just fine!
Rusty
Old 03-17-2006, 09:34 AM
v8440's Avatar
The only brand of aftermarket electric fans I'm aware of that's even remotely worth a hoot is spal. Flexalite is a common brand, sold all over the place. Like most of the rest of them, their ratings are wildly optimistic, as you now see. What I'm saying is, your experience with flexalite fans is not representative of what you could get with high quality electric fans.
I have a friend with a '67 pontiac tempest that has a strong 455 in it, probably 625 hp or so. The car has a/c, and never gets hot. He turned his spal electric fans on for me with an underhood switch. They tried to blow my hand back. This was with the engine off, on battery voltage. It was immediately obvious that all the other aftermarket fans I've ever used are nowhere near in the same league.
The other, cheaper, place you could try is a junkyard. Oem fans are generally pretty good, much better than the cheaper aftermarket fans. You could try to cobble something together using fans from fwd cars with decent sized engines.
Old 03-17-2006, 09:47 AM
Thanks for the input guys. I think he was looking for a direct bolt-in replacement type setup. I'll let him know what you guys have come up with. I think he was just looking for a setup that would flow as well as the stock fan but that was controlled by the thermostat so it would be easier to warm up the truck. He and I only live about 8 miles from work. It's nearly impossible to warm the thing up with this short drive on chilly mornings. I think this was the main reason for him asking.
Old 03-17-2006, 09:52 AM
RustyJC's Avatar
Believe what you will. 0.8 HP is 16% of 5 HP or 4% of 20 HP. Even if another brand's airfoils are twice as efficient, that's only the equivalent of 1.6 BHP. If another brand draws much more than 50 amps, they will draw the battery down at idle (my 50 amp fans would do that in about 10 minutes sitting at idle with the lights on and the A/C running). Also consider that your friend's Tin Indian isn't running 20,000 lbs GCW up a 5 mile 6% grade. As I've said, electric fans will cool mall cruisers just fine.
It's been said that a wise man learns from the failure of others. I've given you my experience. If you work your truck hard, electric fans won't cut it dragging a heavy 5th wheel in the Texas Hill Country in the middle of summer, or dragging that same 5th wheel in Houston traffic. If you choose not to believe me, it's your money!
Rusty
Old 03-17-2006, 10:13 AM
Spooler's Avatar
Been their, Done that, I'll stick with the mechanical fan. He is giving you good advice and so am I.
Old 03-17-2006, 01:58 PM
Dodgezilla's Avatar
Winterfront..........
Diesel Girl
18
10-06-2013 03:03 PM
92smokin blacky
10-07-2011 03:08 PM
Igor
08-06-2007 09:39 AM
big jimmy
07-07-2006 01:33 PM
deputyski
04-03-2005 09:01 PM
Quick Reply: Electric Fan Kits
