Elect Speed/odom.
Old Apr 6, 2010 | 04:52 PM
whosdunit's Avatar
Elect Speed/odom.
Is there any way to bench test a elect., speed/odom.,(90 to 91) before you install it in the trk? the little plastic gears look good in side the 9o mod., i'm putting it in a91 mod., going to do the chrome tape trick i saw on the sticky to illumate dash lites better. thanks.
Old Apr 7, 2010 | 10:55 AM
maybe368's Avatar
I don't recall if you would be able to get voltage to the little motor in the counter unit, but you could put it in just enough to test it, without bezel and such. I found it pretty easy to remove and replace, Mark
Old Apr 7, 2010 | 12:30 PM
whosdunit's Avatar
Hey 368, gears looked good best i could tell ,but i wanted to be sure so i used the "sticky" and took it apart,,,money wasted,,they broke!!!,gages,bezel,the rest of unit goood. i'm still goin try using small batt. chger.,to test mtr. thanks
jrdperformance
Mar 9, 2011 10:54 PM
cowboy_trucker
Aug 13, 2006 02:56 AM
hooked235
Mar 5, 2006 08:22 PM
Kevins
Mar 6, 2005 12:28 AM
taken5875
Oct 4, 2004 12:38 AM
