No Bus In Odom Window
Old Mar 4, 2006 | 02:22 PM
hooked235's Avatar
I Was Coming In Yesterday And The Dash Went Slowly Dead And A "no Bus" Message Came Up In My Odom Window. I Was Told To Check All My Fuses And They All Look Good. Does Anyone Know Of This Or Have Any Ideas
Old Mar 4, 2006 | 04:52 PM
Jeff in TD's Avatar
I think that was the message a friend with a 1500 got. They checked some connections and decided that his whole dash cluster died...
What year is your truck, and is it under warranty?
Old Mar 4, 2006 | 05:09 PM
Jeff in TD's Avatar
PS, If you hold the trip reset button in when you turn on the key, then let off the button, it will put the dash into self-check mode, then display any error codes on the odo window...
Old Mar 5, 2006 | 11:55 AM
AggieJustin's Avatar
Check the plug under the dash, just to the left of the clutch pedal (or where the clutch pedal would be if you're "shiftless"). That's the harness that feeds the dash cluster. Make sure you have a good connection there. Also, if you have an overhead computer, is it displaying properly or does it show "No Ccd"?
When this happened to mine, I could usually get it working by unplugging and reconnecting the harness. But eventually I had to have a whole new cluster installed. I was out of warranty and the process was a real PITA.
Old Mar 5, 2006 | 08:22 PM
rockittboy's Avatar
its a crumby connection behind the gauges or in a harness feeding them. my sisters jeep got it from having the top off year round for 2 years. i just hit the dash really good and unhooked and hooked all the connections and she was good to go.
jrdperformance
Mar 9, 2011 10:54 PM
whosdunit
Apr 7, 2010 12:30 PM
raven392003
Oct 29, 2007 11:39 AM
cowboy_trucker
Aug 13, 2006 02:56 AM
hooked235
Apr 28, 2006 06:05 AM
