edge juice low fuel pressure?
Old 07-08-2009, 12:04 AM
mttjma2002's Avatar
edge juice low fuel pressure? need help ASAP
Just installed edge juice with attitude 2001 auto and my fuel pressure at idle is 11 and when i get into boost it goes down to 3 and then sometimes 2 if i put it on stock it takes it longer to get to 3psi for fuel pressure. Any ideas?
Thanks,
TC
Old 07-08-2009, 12:45 AM
kevellis32's Avatar
Please fill in your signature so we can all see exactly what you are running. You may need a new pump, try to change your fuel filter first though.
Old 07-08-2009, 12:48 AM
mttjma2002's Avatar
the thing is it had a new pump and filter put on last summer.
Old 07-08-2009, 01:41 AM
mttjma2002's Avatar
the onyl thing i could figure is that the place screwed me which they did, long story, however they said NEW pump but maybe they just put a used one on . Now that i have voided the warranty im kind of sol.
Old 07-08-2009, 07:03 AM
Pinkston's Avatar
Lasst summer was a long time ago. Sounds like the pump is done.
Old 07-08-2009, 08:09 AM
nickg's Avatar
if it was a new stock pump, it probably failed again, although I believe even stock pumps have a yr warranty, to my knowledege I can't see how you voided the warranty??? installing J/A should not have anything to do with the LP warranty,.
BTW it only takes one tank of fuel to plug a filter, and the first step in diagnoising any low pressure issue is to replace the fuel filter FIRST. replacing the filter last summer is all the more reason to replace it again!
Old 07-08-2009, 09:32 AM
6_DEMONS's Avatar
Thumbs up
One thing you have to research and remember is that the VP24 has the worst lift pump EVER. I was droping fuel psi to 0 when the drag box was untapped. Basically running as a EZ. Get a air dog 150 or the new 165 and never have to worry bout losing fuel psi or a VP unless its weak. With what's in my sig running 5x5 I can hold to the floor till it runs out of gear and never drop below 15. Make the investment and save your self alot of headaches.
Old 07-08-2009, 11:22 AM
mttjma2002's Avatar
Thanks for the input guys, im running to get a new fuel filter right now! Ill let yall know what the outcome is.
Old 07-08-2009, 04:57 PM
mttjma2002's Avatar
now that its got a new filter i have about 7psi under WOT and 14 at idle and 10-11 cruising. Im still replacing the lift pump because i got one for free so it can only help it out more.
Old 07-08-2009, 05:45 PM
OldDodgeOwner's Avatar
That's right about what I'm running for pressures. A bit low at WOT, but I wouldn't be too worried...
Old 07-10-2009, 12:16 AM
DodgenIt's Avatar
I agree with olddodgeowner. Keep an eye on it for sure though. Once psi drops below 8psi, your vp can get damaged from starving very quickly.
If the new pump starts goin out again, GET a FASS or Airdog. They both have great reps and offer piece of mind thats unbeatable in my book.
Im at 21psi idle, 18 cruising, 13 WOT. good investment all around.
Hope this helps.
Old 07-10-2009, 10:00 AM
Jeff5886's Avatar
You need to run an airdog or fass period.
MrSuzuki
08-25-2009 07:22 AM
REDNECK-WELDING
05-10-2009 01:15 AM
bc3
12-01-2007 10:19 PM
razor6
22
01-20-2006 03:43 PM
djcheez
10-15-2005 04:13 PM
Quick Reply: edge juice low fuel pressure?
