Edge Juice with Attitude Feedback???
Old 04-11-2006, 07:15 AM
Sea01Cummer's Avatar
I just ordered one, how are people liking them that have them????
Steve
Old 04-11-2006, 08:00 AM
BarryG's Avatar
I just put mine in on Sunday. I got it all in and setup except for tapping the pump. Ran out of time it was just getting too late. Will get that done next day I have a bit of time to do it. Install was fairly easy. Directions were good and straightforward. I already had a pyro and fuel pressure gauge port from my gauges. So I just swapped out senders and moved my old pyro to post turbo which was also already tapped but just had a plug in it. I had it all done except for the tap in less than an hour. Since I dont have the pump tapped I cant speak about the performance gains yet as I had an ez in before but it seems to be about the same as that untapped. Some of the monitoring feautres are pretty cool such as fuel temp, intake temp, load % etc and a thumbs up to the turbo timer too which is setable by temp or time.
Old 04-11-2006, 05:25 PM
mooseman's Avatar
Im still lovin mine. No troubles at all.
Moseman
Old 04-11-2006, 05:47 PM
dingoo's Avatar
got mine in yesterday it rocks. much more power amazing how fast it can move a 7000 lb truck
Old 04-11-2006, 06:02 PM
bwarren86's Avatar
works great
Old 04-11-2006, 07:30 PM
RJF
RJF's Avatar
Got mine in when they were first released two weeks ago, love it, lots of features over the Comp.
Old 04-11-2006, 07:35 PM
Is the fuel pressure feature a psi gauge or just a warning light? Tomorrow is the day and i'm jacked!!!!
Steve
Old 04-11-2006, 07:47 PM
Dodgin&Rammin's Avatar
Can I order the monitor for my comp?
Old 04-11-2006, 08:14 PM
RJF
RJF's Avatar
Steve
It's a real digital guage with live fuel pressure coverage! And a warning too!
Old 04-11-2006, 08:44 PM
RJF
RJF's Avatar
Nope, you can't.
Old 04-11-2006, 09:27 PM
Saweeet!!!!!!
Old 04-11-2006, 11:03 PM
GlennRMK's Avatar
Were do you guys have yours mounted?
Any pictures?
Mine should be here this week.
Old 04-11-2006, 11:20 PM
RJF
RJF's Avatar
This is how I mounted mine, there is a little bracket supplied that you use. Running the wire down through the a pillar hole is the fun part....
Old 04-11-2006, 11:53 PM
whiteVLX's Avatar
I mounted mine where the trip computer would normally sit. Pretty easy to carve out the blang plate and route the cable in the headliner and down the a pillar.
Old 04-12-2006, 06:14 AM
I bet it won't be long and someone will make some mounting options for our trucks. Mine should be here today.
Steve
Quick Reply: Edge Juice with Attitude Feedback???
