Edge jammers?
Old 01-19-2008, 10:55 PM
Rammandan's Avatar
Edge jammers?
Anyone here use the edge jammer nozzels or injectors? I was wanting some feedback? which should i do i was wanting to go with the level 3 nozzels but don't know much about them. I was hoping to get a little first hand feedback thanks.
Old 01-19-2008, 11:04 PM
clowndodge01's Avatar
since you got the juice, i just installed mine my next mod is going to be an airdog sys. and the stage 5 jammers
Old 01-19-2008, 11:15 PM
LUKE-MM-PULLER's Avatar
I put my stage 2 nozzles on last winter, I dont have any complaint about them. Good power for the money.
Old 01-20-2008, 12:54 AM
my_samurai's Avatar
im running a edge att and jammer 3's its a really nice set up...good smoke..pently of power....i can roll 315's over from a stop with no brake pedel helping...you love it....about the most i would put on a stock headgasket and turbo thou
Old 01-20-2008, 01:39 AM
Cameronc's Avatar
what kind of mileage and power did the stage 2's give you... Thanks
Old 01-20-2008, 01:40 AM
ncdodgeman20's Avatar
i just put stg 5 in not to long ago and and iam very happy and runing stock turbo with waist gate blocked and i can get 45 psi easy but all aroung great power for the money!!
Old 01-20-2008, 02:14 AM
99globalwarmer's Avatar
save your money for a real set buy the time you get done with balancing your almost at the cost of ddp injectors
Old 01-20-2008, 03:12 AM
powermad's Avatar
im putting a set of stage 4s on today i will let you know if they are worth the money of if you should save and get full injectors
Old 01-20-2008, 04:24 AM
1-5-3-6-2-4's Avatar
I ran jammer 5s on my stock turbo for a while too, big power, hot fast on long pulls. need more air than stock HX35 can give for complete gains.
but worked real good for me, very responsive. Smarty on 9 jammer 5s and HRVP was a kick in the pants. I still have jammer 5s on bodies sitting around since I went to DDPs.
Old 01-20-2008, 09:06 AM
Redliner's Avatar
Im runnin the stage 3 injectors. Good power do have a lope on idle with them. Goes away when I put in the big injectors. Lots of smoke with comp on 5x5, even more with smarty. Other than that good power and decent price. If i were to do it again though I would have saved for a little more time and went with f1's or ddp's my $.02
Old 01-20-2008, 10:32 AM
I get around 14mpg in the winter and around 18mpg in the summer. Ireally noticed the power they gave after I put a boost fooler on. The stage 2s definately made a noticable difference in power, when I added a power puck things really got fun.
Old 01-20-2008, 10:43 AM
psd tuner's Avatar
i like my stage 3s nozzles, i do need a aux. fuel pump BAD. lots of power and they are perdy smokey BUT i dont like the lopey idle.
stroker4501
03-24-2007 04:15 AM
edy
03-12-2007 07:42 PM
CARR
18
01-05-2007 07:47 PM
CottonRam08
16
12-12-2006 07:34 PM
hyunsinsone
16
10-03-2006 01:26 PM
Quick Reply: Edge jammers?
