Edge jammers
Edge jammers
I got a 6sp with 4 10s gears and I pull 1,000 gallan water tanks and 28ft livestock trailers at 65 to 80 so times 90. Will 120 jammers hurt my truck. help model is 02
you wont like the jammer 4's while towing that kinda loads. jammer 3's AT THE MOST.
this is all of course with the stock turbo. you can jump up to a sps 62 and upgrade the clutch and run the bigger sticks.
however, if i was you and if i was going to tow loads (which i do, check my gallery
) i would install some mach 1.6's and either an EZ or a smarty. With a upgraded clutch and turbo of course
you'll have to upgrade the turbo and the clutch. But ya, you can run them. I would defiently run a box with timing on it too though! the timing will lower egts and give you extra kick-in-the-pants
? what else have you done to your truck?!
your DEFIANITLY in for a turbo. do you have gauges?!
if you install some larger injectors (i dont think youll see a big enough increase to offset the price difference) but youll need air. In a bad way. hope you have a pyro....
the 40 hp that you may see going from your 80hp sticks to 120 hp sticks wont really be noticable. But you will see a big increase in EGTS!
i have ran the jammer 4's with a comp before, you have to turn the comp off to tow.
not the same turbo blackdiesel talking about. a cheaper one
check out www.htturbo.com they have nice turbos for decent prices and check the classifieds on here.
heres what i was talking about http://www.citydiesel.net/dodgezilla...cPath=22_27_50
this is not near as good of turbo as the others that are suggested, you will out grow this turbo quickly(usually)JMO.
good luck do lots of searching and you will find a good deal, people almost give them away in the classifieds, sometimes.
dieselfan
