Dss
Old 04-03-2007, 03:11 PM
goodeyesniper75's Avatar
Dss
I am in the market for a DSS where is the best place to get one?
Old 04-03-2007, 04:00 PM
tritont's Avatar
here's one place.... there is another that has it for less but, I can't remember their name. It's was wicken.... diesel. Not Wicked diesel. Maybe someone will chime in that remembers.
http://www.sourceautomotive.biz/steeringsuspension.htm
Old 04-03-2007, 04:09 PM
XLR8R's Avatar
I installed this on my '05:
Old 04-03-2007, 04:29 PM
JD Dearden's Avatar
Are you still doin the 22.5?
Old 04-03-2007, 04:33 PM
Robert373's Avatar
Your probably thinking of "windecker machine". The DSS is made in Canada, so if you are in the US it would be easiest to find an American supplier. You can buy it direct, but it is a pain to get things across the border.
Here is the manufacturer website:
http://www.solidsteel.ca/
OR
You could get XLR8R to build you one.
Old 04-03-2007, 04:35 PM
OldSmokey's Avatar
Ive been thinking of making my own as well, but where do you get the bearing, and do you need a longer shaft?
Old 04-03-2007, 04:42 PM
Robert373's Avatar
The bearing is quite standard. Most bearing supply stores will have them. I haven't figured out a way just yet to lengthen the steering shaft. May have to weld something up that will screw onto the shaft and take it to a machinist to get the extension trued up.
I had a quick look at the shaft. Looks like it is probably 7/8 fine thread, but I am not sure. I will measure and post back.
Old 04-03-2007, 04:51 PM
OldSmokey's Avatar
Thanks Robert that would be great.
Old 04-03-2007, 08:27 PM
wap
wap's Avatar
Maybe a dumb question but what is the advantage of this set up?
Old 04-03-2007, 08:37 PM
i still do want to do the 22.5's
Old 04-10-2007, 12:04 AM
Robert373's Avatar
It took a while, but I finally confirmed the steering shaft nut is 7/8 fine thread.
Old 04-10-2007, 09:38 AM
Hunter11's Avatar
I had a DSS on my old 01.5 and it was one of the best mods I did to that truck. It made the steering feel like it does on my 05, nice and tight. I may add one to the 05 someday.
Old 04-10-2007, 09:58 AM
cquestad's Avatar
It is sweet...should of made my own too. Bearing is easy to source.
The price was so right when I did it...the time was more valuable doing something else.
Old 04-10-2007, 01:20 PM
OldSmokey's Avatar
How is the shaft extended on yor kit cquestad?
Old 04-10-2007, 02:06 PM
cquestad's Avatar
The pitman arm nut is replaced witrh a new nut that has an extended shaft off the bottom. The shaft OD is the flange bearing' ID.
The flange bearing mounts to a plate/tube steel support that mounts in a sandwich with the sway bar mounts at the frame. Easy stuff...except the nut shaft piece...but it would be cake for a machinist.
Quick Reply: Dss
