Driveshaft(s) Removal
Old 03-13-2006, 07:02 PM
Frank Hog's Avatar
Yeh, another vibration thread. My truck went in for the 70MPH vibration problem, they rotated and balanced the tires, said the driveshafts were OK, and sent me on my way. Still has the exact same vibes.
Two Questions:
1. Is the truck still driveable with the front shaft removed?
2. How is the rear shaft removed on the front side? Is it a splined shaft that slides out once the rear bolts are removed?
I think I will get each balanced separately on my own. It's only about $50 each, and it beats going in many times to the dealer to get nothing done, and waste almost half a day.
Old 03-13-2006, 07:22 PM
rockittboy's Avatar
yup, i drive mine every day without a front driveline. as far as the rear, i dont really understand what your askin, i just removed all the bolts where necessary, used a little hammer action and it all came apart.
Old 03-13-2006, 07:28 PM
Ra'am's Avatar
Yes the truck is still driveable with the front shaft removed. You will need an extended 6" T-40 torx bit to remove it from the front yoke. Also mark the shaft and yokes with paint and replace the same way they came off. Don't know about the back, have'nt done that one yet but I would say it is splined.
Old 03-13-2006, 07:34 PM
Geico266's Avatar
You might want to try just putting a standard hose clamp on the drive shaft. I have read several posts where guys swear it helps.
Also, I just added ceramic beads to my tires and it took out all but the slightest vibration. I highly recommend it.
Old 03-14-2006, 08:33 AM
Frank Hog's Avatar
This morning I got the front shaft off and drove the truck -- same exact vibration. So, possibly it's the rear shaft. Was hoping it was the far lighter shaft!
May try the previously suggested hose clamp theory on the rear shaft.
Old 03-14-2006, 08:42 AM
Dodgezilla's Avatar
Anybody getting better mileage driving without the front shaft on the truck???
Old 03-14-2006, 08:44 AM
reecegr's Avatar
try rotating the rear shaft 180 it worked on mine,only takes 5 min.
Old 03-14-2006, 10:46 AM
MOJO1's Avatar
Smile
They put 2 drive shafts in mine still no good But then i talked one tech in to removing one out of another truck which we drove first.Took it out put it in mine prolblem solved ( Mine was the rear shaft.) I have a good dealer
Old 03-14-2006, 05:26 PM
Frank Hog's Avatar
I tried that before the front shaft removal, and it helped a little, I think, but not enough for me. Tomorrow, hose clamp, etc.
Old 03-14-2006, 08:00 PM
rockittboy's Avatar
i noticed 1mpg better...maybe...however at the same time i took it out, i lifted it another 4"
HUNTINNUT
07-27-2013 11:40 AM
trik396
05-21-2009 01:44 PM
trik396
06-01-2008 07:04 PM
Wes3500
10-10-2002 07:42 AM
Quick Reply: Driveshaft(s) Removal
