DRIVER SPEAKER VIBRATION!
Old 09-02-2003, 02:11 PM
cumminsho2500's Avatar
I HAVE THE INFINIT SOUND SYSTEM AND WHEN I TURN THE BASS UP THERE IS ACCESIVE VIBRATION. IT SHAKES THE WHOLE DOOR PANEL WHAT DO I DO???? :-
Old 09-02-2003, 02:44 PM
drafalske's Avatar
Re:DRIVER SPEAKER VIBRATION!
Turn the bass down. Or invest in a high quality aftermarket sound system designed to provide the SPL.
I suppose you could remove the door panel and try a little dynamat to dampen the vibrations. Good luck!
-Dave
Old 09-02-2003, 03:53 PM
Thats MR Hoss to you buddy!
Hoss's Avatar
What he said....turn the bass down. : :P
Old 09-02-2003, 05:19 PM
spots's Avatar
And don't yell. I ain't that deaf. : :
Old 09-02-2003, 11:57 PM
WJB
WJB's Avatar
I had the same problem. So when I took mine to the dealer to have the alternater bracket changed, I told them about the rattling problem. I don't know what they did but they fixed it.
Wade
Old 09-03-2003, 02:25 PM
Hoss's Avatar
[quote author=spots link=board=17;threadid=19139;start=0#msg179737 date=1062541169]
[/quote]
He HAS to yell...he's used to driving around with the bass turned up and he can't hear anything. ;D
Old 09-06-2003, 10:26 AM
Dodgezilla's Avatar
Your replies are all quite funny but mine does it too even if I turn the bass all the way down.. All I need is someone talking on the radio with a deep voice. I may pull the door panel off and try to insulate the speaker with some rubber........
Old 09-07-2003, 07:00 AM
MrBilly's Avatar
I had a similar problem in the passenger side speaker, but not an Infinity - just standard speaker. Dealer ordered new speaker and installed it. I went out after installation of the new speaker and it had the same noise. ???
Went back in and another guy came out. Looked in the door compartment where wife had put a thick piece of paper. Removed the paper and the sound went away. :P
I said, "I guess I didn't need a new speaker afterall." He replied, "no, but we made some money." 8)
Check what is rattling in that compartment on the lower door and remove it. May help?????
Billy
Old 09-07-2003, 06:04 PM
waggoner5's Avatar
I had the same problem with the Infinity system and the front door speaker. I traced it to the window switch panel, the fake wood trim panel, and the felt window trim at the top of the door panel. All 3 of these items were loosly attached and all 3 rattled.
Gary
Old 09-07-2003, 08:11 PM
Al396's Avatar
Same thing with mine, the window switch panel with the regular standard stereo system. Turn the bass down? That sounds like something a dealer would say.
Old 09-07-2003, 10:45 PM
dealseeker's Avatar
I had the dealer tighten up my vibrating driver's side door panel.
loya 3500
12-09-2010 10:48 PM
willTX
10-05-2008 12:51 PM
dodgedsl03
01-18-2007 10:08 PM
BART62
15
04-14-2004 07:47 AM
ouchman
04-29-2003 08:39 PM
Quick Reply: DRIVER SPEAKER VIBRATION!
