Drain Line Banjo
Old 10-08-2005, 12:28 PM
george7941's Avatar
Drain Line Banjo
Is it important to lower the restriction to fuel flow in the fuel drain line? I am going to be replacing the banjos with VulcanWeld fittings and I was wondering if I should replace the drain line banjo. A less restrictive drain line would lead to higher flow but maybe a little less pressure but I am not sure because apparently there is a pressure releif valve in the VP44 and maybe the end result would be no change at all from changing the drain line banjo.
klx650a2
01-10-2008 12:08 AM
ptgarcia
08-18-2006 03:52 PM
Pinkston
04-04-2006 07:46 AM
banks twinram
02-13-2005 04:09 PM
wooff
05-01-2003 11:22 AM
Quick Reply: Drain Line Banjo
