Down but not up......
Old 02-26-2008, 09:34 AM
CODODGE2500MAN's Avatar
So I'm driving to work today and roll the passanger window down and now it won't go up....
any ideas on what this could be? Or how I can get it to go back up at least till I can get whatever part I need?
Old 02-26-2008, 09:46 AM
nkennedy's Avatar
Try bumping the door with your hand down low while hitting the button. Could be a stuck motor, window regulator, or bad motor.
Old 02-26-2008, 09:59 AM
Crimedog's Avatar
Probably just the switch, you can take it apart and lightly sand the contacts to regain a quality connection in the switch.
Old 02-26-2008, 12:46 PM
Dartmouth 12V's Avatar
Are the windows manual or power? It is probably the switch if they are power. If they are manual, the slider tends to fall off the bottom of the glass.
Old 02-26-2008, 02:27 PM
J Lent's Avatar
My truck did that one day, turned out to be a loose fuse in the side of the dash.
Old 02-26-2008, 03:26 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Try pulling it up by hand while someone pushes the switch. When these motors start to go they can get a flat spot in the windings and if you get it moved a tad will work again (until you hit that spot again)
You can at least get it closed till you can work on it
irocpractice
11-17-2012 01:52 PM
twisselman1968
32
07-22-2008 09:43 PM
Evildiesel
11-11-2005 08:13 PM
Scotty
09-11-2005 12:37 AM
Quick Reply: Down but not up......
