Door Lock Sticks
Old Apr 30, 2011 | 08:02 PM
mrbig95's Avatar
Door Lock Sticks
The door lock on my passenger side sticks, and wont un lock without alot of fiddling. What do I need to fix/or replace?
Old Apr 30, 2011 | 09:04 PM
SlingShot's Avatar
Needs to be cleaned and lubed. Look in the sticky for directions.
Old Apr 30, 2011 | 09:16 PM
johnh's Avatar
i took mine apart and lubed it real good, now it works like new
Old Apr 30, 2011 | 11:13 PM
d22019's Avatar
i cleaned mine not too long ago also. I took the whole thing out and let it sit in diesel for a day. The diesel and a little bit of scrubbing got it working like new again.
Old Apr 30, 2011 | 11:45 PM
ofcmarc's Avatar
Pull the latch out and soak it in a can of diesel. Use a stiff brush to get in all the little nooks and crannies real good then hose off with some brakekleen. Relube with some spray silicone and reinstall. Might want to take a look at the condition of the plastic clips that hold the rods in place. If they are worn replace them to take up some of the slop if there is any.
Old May 1, 2011 | 11:30 AM
cougar's Avatar
Another thing to check is your door hinges. If too much door weight sits on the latch, it will bind up the lock.
Old May 1, 2011 | 03:09 PM
15 Digger's Avatar
If it's the key cylinder get tube of dry graphite from home depot and apply in lock and work it in. No oil in locks, will attract dirt and make worse.
Old May 1, 2011 | 04:53 PM
mrbig95's Avatar
OK, thanks for the input! I will clean everything up and go from there.
Thanks,
Preston
Old May 1, 2011 | 06:49 PM
Thiss's Avatar
Going to have to disagree with this one. Tri-flow is locksmith approved.
Old May 2, 2011 | 01:53 PM
15 Digger's Avatar
Never used it but did oil ignition once and got worse immediately so oils scare me. On home door locks when causing problems a shot of graphite makes them work slick for quite a while. Whatever works.
Dynocon
Mar 4, 2008 08:32 PM
staarma
0
Oct 25, 2007 12:49 PM
xp8103
Jun 2, 2006 07:00 AM
Nuttymopar
Sep 2, 2004 07:39 AM
damon_achey
Jun 7, 2004 03:33 PM
