Does my idle really need adjusted or can I tighten the throttle linkage?
Old 08-02-2006, 08:17 PM
Common's Avatar
I tried starting my truck the past few days with a little pedal pressure and I have it to the point where my foot is I mean --- BARELY touching the pedal and it fires right up... I really mean there is virtually NO pressure on the pedal...
So is it my idle?
Throttle linkage?
Old 08-02-2006, 10:12 PM
dslpower's Avatar
Raise the idle speed just a bit. 750rpm in gear w/ac on for an automatic. its really easy to do, 10mm wrench for the lock nut and the idle stop screw.
Old 08-03-2006, 10:11 AM
infidel's Avatar
It's important that the throttle linkage remains at a certain length or your engine won't have the full range of rpms.
Follow the instructions here http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
darkale69
04-23-2012 08:04 AM
ARbowhunter7
03-22-2011 12:49 PM
91.5 beater
12-11-2007 04:58 AM
sajigore
05-22-2006 10:53 AM
Quick Reply: Does my idle really need adjusted or can I tighten the throttle linkage?
