How do i adjust my idle
Old Jun 2, 2006 | 09:15 PM
pred's Avatar
I would like to raise my idle just a tad, it seems a bit too low, sometimes in heavy work traffic, you know, 1 block 3 minutes, it starts to idle a bit lower, and starts to shake a bit, All i need to do to stop this shake, is run it through 2nd and 3rd, then is ok for ten minutes, Thinkning the idle is just a bit too low for getting stuck in that kind of edit,
Thank you!
Peter
Last edited by wannadiesel; Jun 2, 2006 at 09:17 PM. Reason: profanity spelled with symbols
Old Jun 2, 2006 | 10:52 PM
loch's Avatar
As you look at the injector pump from front , on left side between engine and pump id the idle screw, loosen the jamb nut and screw it to the desired idle. PS the nuts kinda hard get to, use a punch to tap it loose.
Big Deezul
31
Mar 14, 2022 12:41 PM
gomerpile
Jan 31, 2008 05:08 PM
jstrdiesel
Aug 22, 2007 03:47 PM
VADSLRAM
Oct 20, 2006 08:27 AM
Ram of Steel
Jun 15, 2006 10:05 AM
