how to disable DRL?
Old Jan 28, 2009 | 10:22 PM
good ole boy's Avatar
how to disable DRL?
I need to disable my daytime running lights on my 05 dodge. (canadian model)
Can I just pull a Fuse?
Im installing HIDs and they need the DRL disabled.
thanks for any help.
Old Jan 29, 2009 | 09:34 AM
worldindustries's Avatar
dealer can do it with starscan tool, must change country code to us first and I hear bullydog can do it too, someone else might be able to help, I need the same done too
Old Jan 29, 2009 | 09:42 AM
cbrahs's Avatar
swing by the dealer to have them shut them off
Old Jan 29, 2009 | 09:54 AM
stroker101's Avatar
ur sig shows u have a triple dog. does it not have that feature to "enable" and "disable" DRL? mine does
Old Jan 29, 2009 | 11:06 AM
spider_1954's Avatar
Not sure if Bully Dog will do an 05 or not and I would thing that the Dealer would not do it in Canada since that is a law to have them and all.
You may have to come to the US to get it done.
Old Jan 29, 2009 | 03:59 PM
KWhitelaw's Avatar
I can disable with Bully Dog on my 06 so hopefully can on the 05?
Old Jan 29, 2009 | 06:06 PM
I dont think the dealer will do it here in Canada because its a Law
I only think the bullydog will do it on the 06 and newer ones
Headlights on the 05 are not controlled buy the computer.
thats what I thought I could just pull a fuze or a Relay
Old Jan 29, 2009 | 09:37 PM
AlK's Avatar
AlK
If you are in an accident and the insurance company finds out that the DRL's were disabled you may not have any insurance - be careful.
Old Jan 29, 2009 | 10:31 PM
Fat Tom's Avatar
There should be a DRL module somewhere, I haven't looked for it on my 05, but on my 2000 it was mounted on the drivers side fender, and I had a dakota that was also on the drivers side fender. Just unplug that and bye bye daytime running lights. Only problem I had with that was for some reason it was tied into the high beam indicator light. If the module was disconnected, the high beam indicator light would not work.
Old Jan 30, 2009 | 01:05 PM
055055.9's Avatar
Disabled mine using DRB3. Had to change the country to Canada to allow access to the feature to enable/disable. Disabled changed back to USA good to go.
Old Jan 31, 2009 | 10:07 PM
davinski's Avatar
One click on the parking brake used to disable my GM DRL.
BDdiesel
Jun 19, 2013 10:48 PM
deewweed
Nov 1, 2007 12:05 AM
RODGERDODGER01
Aug 13, 2006 05:00 PM
JIMCTD
Mar 30, 2005 12:51 PM
Lil Dog
Feb 21, 2004 12:44 AM
