DRL and parking brake ????
Old Aug 13, 2006 | 08:15 AM
RODGERDODGER01's Avatar
Just recently my Daytime Running Lights have stopped working and I think it has something to do with my Parking brakes, I used them frequently and noticed before that when you apply the brake when truck is running the lights shut off. Just yesterday I was trying to troubleshoot the problem and I was pushing on the pedal and releasing it a few times and the lights came on for a split second and shut off, and couldn't make them go on after that. I looked at the single wire at the pedal but couldn't see anything wrong with it, could use some feedback if anyone has encountered the same problem and rectified it.........thanks
Old Aug 13, 2006 | 10:26 AM
OutlawStorm's Avatar
Is the brake pulling all the way off? Like once you release the emergency brake can you pull the pedal any further up towrds you? It only takes 1 click of the brake to shut the lights down. All that switch does is provide a ground, that will turn the Brake light on the dash and also turn of the Daytime running lights.
Old Aug 13, 2006 | 11:04 AM
Homestead's Avatar
Pull the brake release and hold it while lifting the park brake pedal with your foot. If they come on, you need to just adjust the switch.
It happens quite often on trucks that have thier park brakes out of adjustment, mainly when you release the brake, the pedal doesn't come up enought to trip the switch.
Jeff
Old Aug 13, 2006 | 04:10 PM
Ya I tried that,the pedal is all the way up.....the only thing I should piont out is unlike other vehicles I've had, this one when you apply the parking brake the pedal comes back up and brakes remain applied, is that normal ?
Old Aug 13, 2006 | 04:13 PM
One other note,the parking brake light in the dash does turn off when I release the parking brake.
Old Aug 13, 2006 | 05:00 PM
Sounds to me like its a bad switch being the park light does not turn off,,,, it may be dirty or even rusty as to why it may not be shutting it off and keeping your DRL s off to. There might be an adjustment on the switch,, not sure cant remember last time i was under there looking at it
blacklab467
Dec 15, 2012 06:45 PM
Tazman
Nov 5, 2010 10:44 PM
deewweed
Nov 1, 2007 12:05 AM
Lil Dog
Feb 21, 2004 12:44 AM
