Dash lights not working???
Old Jun 24, 2008 | 02:46 PM
rtroutman69's Avatar
So I got my pillar gauges mounted and wired and I seem to have lost my dash lights. I don't have power to fuse #14 which I think is my fuse for the dash lights. I used an inline connector to wire pillar gauges into the headlight wire (Light green)and they are working fine. Any thoughts would be wonderful
Old Jun 24, 2008 | 02:50 PM
Not to be insulting, but have you tried turning the dash lights all the way up? If it's not operator error it's the headlight switch.
Old Jun 24, 2008 | 02:58 PM
You can't insult me I'm not smart enuf to get it!! But yes I did turn the old switch and the new (just installed) and can't get anything. Am I testing the proper fuse. (Lavender 3 amp) Do you think I may have disconnected a ground?
Old Jun 24, 2008 | 03:03 PM
14 should have variable voltage when the dash lights are on. Disconnecting the ground would not cause you to lose power at the fuse.
Old Jun 24, 2008 | 06:04 PM
edwinsmith's Avatar
The wiring for the instrument lights is a separate circuit from the headlights and is on a separate fuse. The HL switch on these trucks is notorious for going bad and also the plug will get hot and sometimes melt and cause problems.
I solved my problems with 2 toggle switches. one for the headlights and the other for the rest.
I have a diagram if you need it. PM me and I'll post it.
Edwin
Old Jun 24, 2008 | 08:32 PM
Thanks Edwin and Wanna,
I'm going to work at it a little bit longer to see if I can figure it out. And if my usual troubleshooting skills prevail, I'll be sending you that PM within the week there Edwin.
Randy
Old Jun 28, 2008 | 10:56 AM
I Hate electrical stuff! Because it's always something stupid that I miss. So for info purposes only, if your dash lights and parking lights don't work and you don't have a blown Fuse # 14 (dashlight fuse), then check Fuse # 4 (horn relay) before buying a new switch. Because apparently that fuse is on the same circuit but is before the dash light fuse. If I could read a schematic I would have seen it but I can't so I didn't.
Have a good weekend
Old Jun 28, 2008 | 08:13 PM
edwinsmith's Avatar
Headlight wiring diagrams - 1989 - ?
Old Jun 28, 2008 | 08:24 PM
Thanks Ed,
Mine is just a little different(I think) but I still can't read them.Notes
Headlamp Switch
Old Jun 28, 2008 | 08:25 PM
I don't know how to post the diagram!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 28, 2008 | 08:32 PM
edwinsmith's Avatar
The best way is to have the image posted on a web server and then in your post click the yellow button that looks like 2 mountains with a sun (moon?) and enter the URL of the image.
For example the URL of one of the images is http://www.freeholdconsulting.com/dt...headlight1.gif
Otherwise you have to submit the image to DTR and wait for an admin to review it before it will show up.
Regards
Edwin
Old Jun 29, 2008 | 10:16 PM
maxx250's Avatar
Glad you got that worked out Randy,unfortunatley the drive to Charlotte has gotten a bit longer for me.The electrical stuff on these things can really be a challenge,mine has left me scratching my head more times than I like to count.
Sleigher
May 4, 2017 02:12 PM
Don T
Feb 19, 2011 10:15 PM
NoSparkplugs
17
May 17, 2009 10:36 PM
Palmetto_kid
Jul 19, 2005 08:12 AM
CHarlan
Aug 6, 2003 08:40 PM
