Dash Light?????????
Old 05-09-2007, 01:19 PM
tbarbee1's Avatar
Arrow Dash Light?????????
Ive disabled the seatbelt chime is it possible to disable the Light on the dash ?
Obviously I could resort to cutting a wire or a little black tape. I just wandered If there was a secret set of on... off... mumbo Jumbo Key Switches some one knew about.
Old 05-09-2007, 07:16 PM
JWillms81's Avatar
I havent done it yet but I was thinking of taking a jumper wire and hooking it up under the seat where the wires are at. All it is is a plug that plug into the seat belt, pull it run the jumper and if Im thinking right your dash will think the belts pluged in and the light will be gone.
Like I said I havent done it yet but Im thinking it will work, if not its a pretty easy fix so not much time wasted.
JW
Old 05-09-2007, 07:38 PM
CatDiesel_762's Avatar
You can use a jumper wire. However, I thought you should know that your Airbag controller will be affected by that jumper wire. The Airbag controller take the information of the seat belt being engage or disengage and uses it to determine how to deploy the Airbag. Preventing you from either getting hit in the face with the Airbag deployment, or cushioning your head from the whip-lash and impact with interior of the vehicle.
NoSparkplugs
17
05-17-2009 10:36 PM
TGriffith
12-08-2006 10:34 AM
johnny5.9
10-19-2006 10:37 AM
TopGun
04-16-2006 05:54 AM
megajoltman
04-13-2006 02:58 PM
Quick Reply: Dash Light?????????
