Dana 80
Old 12-12-2003, 01:36 PM
clc900's Avatar
Dana 80
How can I tell if a truck has a dana 80?? What did they come in and what distinquishes them from the dana 70?? I am looking at 96-98.4 2500 4x4.
Thanks!
First Post!!!
Old 12-12-2003, 02:29 PM
RCW
RCW's Avatar
Re:Dana 80
If you have the 2500 HD, you will likely have the 80, if you have a regular 2500 you have the 70.
Dodge uses a hybrid rear axle on the Ram 2500HD and 3500 equipped with Cummins diesel engines. This hybrid uses Dana 70 axles shafts mated to a Dana 80 center section (including the carrier, ring gear, and housing).
The Dana 70 carriers are the same size as the Dana 80. The Dana 70 carrier is a multipiece design, while the Dana 80 uses a stronger one-piece unit.
Also, look down on the housing below the axle tube mount, and to the right of the differential cover on the web that supports the casting in which the tube is installed, and you will find a double digit number stamped in the casting. It will either be 70 or 80.
Old 12-12-2003, 08:49 PM
Bob V's Avatar
Re:Dana 80
The 2500 autos had 70's. The 2500 manuals had 80 hybred. All the 3500 had 80's
Old 12-12-2003, 09:15 PM
clc900's Avatar
Re:Dana 80
So is the D70 stronger than the hybrid D80?? I would guess "yes" but only in the carrier???
Also, how do I know a 2500HD from a regular 2500???
I am searching for a truck and currently do not have one YET!!
Thanks!
Old 12-13-2003, 04:15 PM
jman's Avatar
Re:Dana 80
if you open the hood and look up there should be a tag telling you every thing on the truck , it would say"dana 70 , or 80 and gears in 3;55 or 4;10 hope this helps
tankeryanker
01-19-2005 04:18 PM
Mechanos
01-22-2004 12:45 PM
matthopp
11-21-2003 04:49 PM
mcevins
07-03-2003 02:06 AM
Stamey
04-18-2003 10:34 PM
Quick Reply: Dana 80
