Starter Sticks
Old Dec 11, 2003 | 04:19 PM
turfquip's Avatar
Starter Sticks
Hello all,
On the used truck I just bought ('96 5.9, 210, 5 sp) the starter would stick and make a squealing sound for 10 or more seconds then finally disengage. When the truck is warmed up it still does it but for only a second or two. Watching the voltage meter on start up, the needle stays pegged until the noise quits...
I've replaced the starter with an OEM unit, and the ignition switch thinking it could be the culprit. No luck, it still does it.
Any ideas?
Old Dec 11, 2003 | 04:28 PM
Palmetto_kid's Avatar
Re:Starter Sticks
at first i was thinking starter contacts, but you say you replaced the starter, so it cant be the contacts. i am stumped. ???
Old Dec 11, 2003 | 06:32 PM
Helicopter Dan's Avatar
Re:Starter Sticks
it wasn't on my Dodge, but I had a truck once and older one that I had to manually back the ignition switch off the start position otherwise the starter would stay engaged. maybe the switch is keeping the starter engaged
Old Dec 11, 2003 | 06:45 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Re:Starter Sticks
There is a recall on the 96 trucks regarding the ignition switch and heater relay. You need to call Chrysler and give them the vin# so they can see if the recall has been done.
The switch is bad, and it may have been caused by the recall NOT being done properly.
Old Dec 11, 2003 | 06:46 PM
turfquip's Avatar
Re:Starter Sticks
New switch installed today and did not remedy the problem.
This is on a Freightliner FL 60.
Old Dec 13, 2003 | 10:53 PM
Scubasteve's Avatar
Re:Starter Sticks
THere should still be a realy which picks up the solenoid on the starter. Have a buddy start the truck and afters its running and the starter is still engaged pull the realy out, this will narrow it down atleast so you know its after or before the relay.
Relay should be in the distribution box.
Jason
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
TIM-D-FARMER
Jan 6, 2003 08:32 PM
