dana 80 for a '01
Old 06-25-2010, 04:02 AM
AKsmoke's Avatar
dana 80 for a '01
hey guys quick question, my old ladys truck needs a dana 80 (preferably with disk brake conversion)... now ive looked hi and low all over alaska through junkyards and even some backyards. now as dumb as this sounds im out to get her one for our anaversery... anyone got a lead on where i could pick one up in the states?
(just a fyi shes got a 01' 5.9L lifted cummins 2500 longbed, extended cab)
thanks guys
Old 06-25-2010, 08:53 AM
Mechanos's Avatar
DRW or SRW? Just curious, but what's wrong with her axle? Why can't it be fixed?
Old 06-26-2010, 03:24 AM
AKsmoke's Avatar
single rear, and its clunking out a little, and its also not beefed up, i think its like a dana 60 or 70 cant remember... long story short the truck has 287k miles on it and parts are just starting to fail... she happen to mention a dana 80 with disk brakes would be nice and so i was trying to accomidate her.
but yeah its just clunks some times when you take off, we figured swap it while it needed fixing before it had to be fixed
Old 06-27-2010, 11:45 PM
dodge24's Avatar
Check out car-part.com. You can search wrecking yards near you for the exact part you are looking for! I have used it several times for hard to find items. Good luck.
Old 06-28-2010, 04:36 AM
AKsmoke's Avatar
thanks, ill look into it
Old 06-28-2010, 06:19 AM
j-fox's Avatar
So, it's an auto trans truck?
Old 06-30-2010, 08:15 AM
AKsmoke's Avatar
yep, fact trans just got replaced less then 2k miles ago, and beefed up
Old 07-03-2010, 08:48 AM
jeomelia's Avatar
If all other sources don't turn up a rear end, try one of the re-builders, ie Jasper in Indiana http://www.jasperengines.com/ at least it will have a warranty. That is what I had to do, I had spun a bearing and looked for a rear end to rebuild with no luck.
Old 07-08-2010, 10:38 PM
The Guru
Mike Holmen's Avatar
Find the adapters for the dana70 and see if they fit. I don't think that a dana 80 was ever done as a disk brake. Mines a dana 70, with disks. I'm doing my new rear axle up by just transfering the brackets. Might just use the ford stuff and get different rims. Ford super duty used larger brakes and larger bolt pattern. I want to build up a dana 60 with kingpins, using the ford parts just makes it easier/cheaper. At least thats what I got on the go...
Old 07-09-2010, 07:04 AM
Don T's Avatar
I just replaced the rear brake cylinders to a larger cylinder from a ton CHV and now have much better brakes on my 2500 ,1995 5.9L lifted cummins longbed, extended cab 4x4. It was worth the effort for $19.00 each.
Old 07-09-2010, 09:07 AM
The Guru
I was wrong they did make a dana 80, in 2002 2500 for either LWB or SWB. Mostly behind six speed trucks. Going to be rare stuff. I would just buy the adapters and build your old dana 80 up with disks or do the chevy fix for the drums.
Old 07-13-2010, 02:29 PM
AKsmoke's Avatar
ok so sounds like everyones telling me trying to find a 80 is pointless lol, just go build up something to a 80... ill look into the chv fix first once i return to the states thanks guys
tankeryanker
01-19-2005 04:18 PM
Mechanos
01-22-2004 12:45 PM
matthopp
11-21-2003 04:49 PM
mcevins
07-03-2003 02:06 AM
Stamey
04-18-2003 10:34 PM
Quick Reply: dana 80 for a '01
