Cutting Out
Old 12-31-2009, 11:26 AM
Redneck24V's Avatar
Cutting Out
Was wondering what it could possibly, my truck anywhere from 1800-2500 rpm seems to flutter and cut out when under a load and when put to WOT. I do not have a fuel pressure gauge on the truck. It did pull the 1693 code which i understand just tells me there are other codes, but are there any suggestions on what this could be? Sometimes this problem is bad, and sometimes you can hardly notice it. I noticed it for a day, and parked it since.
Old 01-01-2010, 04:43 AM
x1phats10x's Avatar
mine is doin the same thing. my local cummins guy told my that my ecu is going bad jus havent had time to fix it
Old 01-01-2010, 02:27 PM
98.5Hotrod's Avatar
Possibly low fuel pressure at those rpms. Your fuel pump may not be keeping up with the demand.
Old 01-01-2010, 04:24 PM
scottsjeeprolet's Avatar
Is this performance related?
Old 01-04-2010, 12:37 AM
ellerman's Avatar
Could be your throttle position sensor. Do a search for resetting your APPS and try that.
Old 01-04-2010, 11:45 AM
milesfelix's Avatar
My vote is for low fuel pressure.
Old 01-06-2010, 07:31 AM
matthais's Avatar
mine did that to was my vp pump piston sticking when i lug it and stomp on the pedal it would surge bad but when i ease into it was no problem.
TexasBlake
12-01-2004 10:00 AM
Cruzer75
01-19-2004 08:25 AM
herb
01-15-2004 12:12 AM
Jewel
02-05-2003 05:24 AM
Quick Reply: Cutting Out
