Cutting Out
Old Dec 31, 2009 | 11:26 AM
Redneck24V's Avatar
Cutting Out
Was wondering what it could possibly, my truck anywhere from 1800-2500 rpm seems to flutter and cut out when under a load and when put to WOT. I do not have a fuel pressure gauge on the truck. It did pull the 1693 code which i understand just tells me there are other codes, but are there any suggestions on what this could be? Sometimes this problem is bad, and sometimes you can hardly notice it. I noticed it for a day, and parked it since.
Old Jan 1, 2010 | 04:43 AM
x1phats10x's Avatar
mine is doin the same thing. my local cummins guy told my that my ecu is going bad jus havent had time to fix it
Old Jan 1, 2010 | 02:27 PM
98.5Hotrod's Avatar
Possibly low fuel pressure at those rpms. Your fuel pump may not be keeping up with the demand.
Old Jan 1, 2010 | 04:24 PM
scottsjeeprolet's Avatar
Is this performance related?
Old Jan 4, 2010 | 12:37 AM
ellerman's Avatar
Could be your throttle position sensor. Do a search for resetting your APPS and try that.
Old Jan 4, 2010 | 11:45 AM
milesfelix's Avatar
My vote is for low fuel pressure.
Old Jan 6, 2010 | 07:31 AM
matthais's Avatar
mine did that to was my vp pump piston sticking when i lug it and stomp on the pedal it would surge bad but when i ease into it was no problem.
TexasBlake
Dec 1, 2004 10:00 AM
Cruzer75
Jan 19, 2004 08:25 AM
herb
Jan 15, 2004 12:12 AM
Jewel
Feb 5, 2003 05:24 AM
