Crazy Larry- Clutch?
Old 04-08-2007, 03:34 PM
Lambo's Avatar
How long will my clutch hold up with the Crazy Larry?
Old 04-08-2007, 04:03 PM
Fisherguy's Avatar
You tell me when you find out!
I've only run extrreme so far, I'm pretty sure CL will mean a new clutch and I don't need that right now, extreme is plenty for me.
Old 04-08-2007, 06:45 PM
973604x4's Avatar
all depends on how you drive.
now since i don't see the point in running crazy larry if you arent gonna romp on it, your clutch won't last very long.
Old 04-08-2007, 07:57 PM
drewblood's Avatar
hard to say my stocker is holding up even pushing 43.5 lbs of boost the superchips 3805 would slip it worse but like c/l better
Old 04-08-2007, 10:23 PM
2002Dodge's Avatar
It only took 3000 miles for mine to start slipping. Put it in at 18k and slips at 21k. Works fine on everything but CL.
Old 04-09-2007, 08:14 AM
Lambo's Avatar
.......... bump
Old 04-09-2007, 09:11 AM
ronc's Avatar
Clutch
My 06' is slipping on performance, if that gives you any idea.
Old 04-09-2007, 09:36 AM
dditt0635004x4's Avatar
i ran the crazy larry for about 6000 miles before it's started to slip, but once it started slipping it went out really fast.
Old 04-09-2007, 08:52 PM
Lambo's Avatar
What do u suggest going with if it does go, con ofe or fe, whats better and what do they run, and where is it most likely to start slippin, like what speed/rpm range?
Old 04-09-2007, 10:26 PM
DTR's "Secret Agent"
RAT_03's Avatar
not long at all
Old 04-10-2007, 04:08 PM
Lambo's Avatar
.........bump
Old 04-10-2007, 07:36 PM
Robert P's Avatar
mine first stocker started to slip with only the performance setting on the BDTD.
as for which clutch to go with, that all depends on the power you want to have? after you decide how much power you plan on having then chose the clutch that better suits your needs, also factor in how much towing you do?
theres no doubt in my mind that which ever route you chose just make sure its a southbend.
Old 04-10-2007, 07:56 PM
Jim Dynomite's Avatar
I've run the CL with the stock clutch, I also have a dually so the tires don't want to break free as easily as a SRW.
It will slip very easily if you get on it, sometimes it takes a little while for the clutch pedal to get its pressure back.
As far as getting a different clutch, be careful and do your homework. Some clutches can hold a lot a power, but they can chatter and tear up other things downstream of the clutch.
I have a ConFe on my 99 and it has slowly worn out the drivetrain, although it will defitnitely hold the power.
I guess what I am saying is, don't bother running the CL unless you have money to burn, you don"t plan on putting alot of miles on your truck, or you don't mind having a slightly undependable tow vehicle.
.............Jim
Old 04-10-2007, 10:52 PM
Lambo's Avatar
Old 04-11-2007, 01:19 PM
Lambo's Avatar
bump...............
Quick Reply: Crazy Larry- Clutch?
