commander ?
Old 06-16-2007, 02:14 PM
shortbed rv's Avatar
commander ?
I just installed the Quad commander. Now my XZT goes through the led code and then goes blanK. No boost pressure. I selected the module XZT from the menu. Is my problem the MAP connection. I connected where the XZT harness plugs into the MAP.
Any suggestion?
Thanks for your response, I will be back in a couple of hours.
Old 06-16-2007, 04:32 PM
JuzPlaneKrazy's Avatar
I know theres 2 wire's that you have to splice on, I was geting some strange readings too, and after I asked Quadzilla they told me to check them and make sure they were makeing good contact.
After checking the wires and re-crimping the splice's eveything is back to normal.
Old 06-16-2007, 05:05 PM
I have boost now, but no XZT.
Old 06-16-2007, 06:29 PM
I disconnected the XZT from the Commander and the XZT is working. I think the Commander is suppose to control the XZT but I could only find the module selection. I could not find a menu for controlling the XZT.
Old 06-16-2007, 08:46 PM
donhov's Avatar
The earlier ZXT's required a modification from Quad to make them work with teh Commander. Get your serial number and call Quad to see what the status of yours is and if it requires the mods to be done.
Old 06-16-2007, 09:09 PM
XZT serial # looks like 36265. I think the XZT is a newer one because it goes through the light codes and ends on red.
Commander verison 1.4.3
Old 06-17-2007, 08:32 PM
qzilla's Avatar
OK, first make sure that you have the XZT connected to the right port on the Commander wiring harness. On the Commander side it should be a 4 pin connector but, it only has 2 wires in it, they are black and white.
Then go into the menu and go to the module selection and choose a Quadzilla XZT.
The next thing you need to do is when you hook it up to the Commander see what Power Level it is in on the display. This is on the right hand side in the middle. If it is in 0 then the LED will turn off. As you push the up button the number will change and the LED should go green (L1) orange (L2) and then Red (L3) which is the 65hp setting.
Forgive me if you have gone through this I just want to cover the basis first. We will get you up and running ASAP!
Old 06-17-2007, 10:36 PM
Thanks qzilla, All I had to do is push the up button. Everything works. I had read where the Commander defaults to 0 but could not figure out how to increase the level.
Now I am a happy camper, thanks again
Old 06-17-2007, 10:38 PM
DTR's 'Go to Guy'
vzdude's Avatar
not to hijack, but did you buy the A pillar mount? How did it fit?
Old 06-17-2007, 10:40 PM
Big T's Avatar
I did and it fits like a glove and matches the color almost perfect it looks SWEEEEEEEEEEEET
Old 06-17-2007, 11:06 PM
No a-pillar mod. Just used the double sided tape and mounted the Commander next to the a-pillar.
stock03
11-09-2006 11:27 PM
Monty
03-31-2004 08:34 PM
Barrett_Fodder
03-03-2004 07:15 PM
rossn2
02-23-2004 07:34 AM
y-knot
0
09-08-2003 05:29 PM
Quick Reply: commander ?
