cold starting
Old Jan 4, 2009 | 05:35 PM
albertahunter's Avatar
cold starting
what happens is when the truck has sat over night when i go to start it in the morning it will turn over and almost start but not quite, then i'll crank it over again and away she goes. it will do this about 80% of the time but not always.and once it has ran it will start on the first crank every time unless it sits all day then it's the same thing. i did have a power puck but have taken it out.is it a sign of injectors going.
Old Jan 4, 2009 | 05:43 PM
Rollin'_Coal's Avatar
Does it run rough and smoke alot when you start it? If so i would bet on injectors. I see your from alberta, I live in fort st john BC and had the same problem with the cold weather and idling lots. I called chrysler canada and got approval to take it to a shop other than the dealer for warranty and the other shop put in 90 horse injectors on the warranty claim as they cost close to the same amount as new stock ones. i would give that a try.
Old Jan 4, 2009 | 05:45 PM
oh, i just noticed your trick is an 04 so probly no warranty, try a set of 90 horse injectors and if your running a chip or programmer an airdog fuel pump or something along those lines will help reduce injector problems too.
Old Jan 4, 2009 | 11:26 PM
AlK's Avatar
AlK
In really cold weather I cycle the key twice before I turn it to the start position. Started my 92 in -29 F in the bush after sitting for a couple of days.
Old Jan 5, 2009 | 01:46 AM
AkTallPaul's Avatar
How cold is cold?
Are you plugging in?
What all do you have for heat?
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Hummin Cummins
Nov 18, 2002 12:41 AM
dodgeman01
Nov 14, 2002 06:08 AM
