Clutch adjustment ?
Old May 24, 2009 | 07:39 PM
Cory's Avatar
Clutch adjustment ?
I have a 1989 W250 4wd. Is there a way to adjust the clutch? It is difficult to shift and doesn't seem to disengage the clutch completely? Perhaps the clutch hydraulics need to be replaced?
Old May 24, 2009 | 07:42 PM
bradshaw106's Avatar
i just tore apart my setup and it dosent look like their is an adjustment. i do know their should be a plastic bushing on the end of your slave cylinder you might want to check that. heard that might cause problems.
Old May 24, 2009 | 07:43 PM
Riflemanusmc's Avatar
Registered user
Check your fluid level..
Old May 24, 2009 | 08:15 PM
The bushing between the pedal and master cylinder pushrod wears out. If your clutch pedal is lower than your brake pedal, that is your problem.
Old May 24, 2009 | 08:33 PM
Registered user
How many miles, and is it the factory clutch?
Old May 24, 2009 | 08:43 PM
Cory's Avatar
205,000 miles. replaced clutch approx 50,000 miles ago. Clutch has no chatter and does not slip
Old May 24, 2009 | 10:54 PM
Alwaysworking's Avatar
alwaysonDTR
mine works fine with the pedals that way
Old May 25, 2009 | 05:44 AM
Let it wear a while longer.
Old May 25, 2009 | 05:53 AM
PapeCAT's Avatar
If your input shaft is not rotating freely inside of the flywheel, it will be hard-er to shift as you described. Do you have the input shaft bearing or brozne stock bushing.
BCB
Mar 6, 2006 04:20 PM
FORDNOMORE
Dec 31, 2005 10:09 PM
edwinsmith
Mar 19, 2005 08:45 PM
Altaboy
Nov 3, 2003 01:19 PM
