Cleaning air filter- help
Old 01-11-2007, 02:42 PM
s. hale's Avatar
I'm cleaning my Scotty 5 unifilter. Have cleaned the red outer filter, no problem.
What about the inner filter that has a wire mesh inside. This unit doesn't come apart. Do you just spray cleaner on the inner filter, outside and inside and then dunk the whole unit in a bucket of water?
Old 01-11-2007, 04:32 PM
s. hale's Avatar
I found an old thread which asked the same question.
You do clean and oil the gray filter ( along with the red outer filter), which comes as a unit that you can't dis-assemble.
I used the cleaning and oil kit from Unifilter and the whole process was very easy. No instructions came with the kit or from Scotty, whom I purchased the kit from.
I used the hot exhaust from my central vacuum system to dry the filters.
Old 01-11-2007, 05:04 PM
BigDave12768's Avatar
I read in a post before that you should submerge the air filter in hot water and add some simple green or a type of degreaser overnight. Then in the morning skim off the grease that floated to the top and let dry and re-oil. I might be wrong but I think that was the best idea on cleaning filters
DPatton
06-10-2009 02:01 PM
xtoyz17
02-22-2009 07:25 PM
zack birge
10-29-2008 07:36 AM
Wildhog
13
08-04-2008 08:07 PM
nfsommer
04-16-2007 09:21 PM
Quick Reply: Cleaning air filter- help
