class V hitch dragging the ground????
Old 07-17-2011, 07:06 PM
moneytlks01's Avatar
hey guys im was working on the truck some and my new curt mfg class V hitch came in and i installed it. only problem is that when bolted up its around 10" off the ground and my truck is on 35" tall tires! has anyone else run into this??
picture for reference...
Old 07-17-2011, 07:18 PM
ARbowhunter7's Avatar
That doesn't look right. A Class V can have thicker steel, more surface area on the mount, a 2" 1/2 receiver, or a larger hitch frame overall, but it should fit/look very similar to a Class III or IV.
Old 07-17-2011, 07:32 PM
maybe368's Avatar
I hope that you don't mind, but I enhanced the pic to make it easier to see:
http://www.flickr.com/photos/63170901@N03/5948114039/http://www.flickr.com/photos/63170901@N03/5948114039/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Looks waaaaay too low tome Mark
Old 07-17-2011, 08:36 PM
cuminpwrjr's Avatar
I put the same hitch on my 05 work truck and it mounts just below the stock one and it seemed quite low to me as well, not sure how high off the ground it is but it worked surprisingly.
ill see if i can measure it up tommorrow
Old 07-17-2011, 09:05 PM
366 Spring Chicken
Richie O's Avatar
That must be the wrong hitch or something. I have a hitch on my 89 and 92 that was made for them and the reciever is just under the bumper. That would be well under your bumper if you had one. That could drag pretty easy. I would give the seller a call and double check the part numbers, or it even could have been missboxed.
Old 07-17-2011, 09:14 PM
pwrtripls1's Avatar
I believe that hitch mounts not under the frame rain, but on the top side. That will put it right about perfect under your bumper. Try mounting it there and see what you come up with.
Old 07-18-2011, 07:55 AM
here is the link to the mfg's website. this is the part number i ordered and the exact hitch i received according to the picture
http://curtmfg.com/index.cfm?event=hitch.search
here are the instructions. the hitch is isn't wide enough to mount on top of the frame rails and too wide to fit in between them...
http://sitepro12.sitepro.com/masterl..._15012_INS.pdf
Old 07-18-2011, 09:13 AM
maybe368's Avatar
Besides being too low, I would think that the leverage from a 10000 lb load, on a hitch hanging that low, would be tremendous. It also looks, to my bad eyes anyway, that the side pieces that angle down, appear shorter in the PDF than in the foto. Maybe it's one of those 1 size fits none things...Mark
Old 07-18-2011, 11:17 AM
archer39's Avatar
I purchased the same hitch 4 years ago and mines not that low nor is it designed like that. I'll take a picture later.
Old 07-18-2011, 12:46 PM
Falcon1's Avatar
Looks like you got the hitch for a drop bumper.
Old 07-18-2011, 05:39 PM
i guess ill have to call them as i dont have a drop bumper and the add says nothing about it????
Old 07-18-2011, 08:39 PM
Onemoparnut's Avatar
Looks like it might be for a drop bumper to me also. Are those clear tail lights or am I seeing things?
Old 07-19-2011, 06:57 AM
yes they are clear taillights...
Old 07-19-2011, 08:38 AM
Sorry to hi jack your thread but where did u get them I have never seen them for our trucks.
Old 07-19-2011, 04:44 PM
Bill- http://www.memoimports.com/mi/index....rucks&cat_id=9
Quick Reply: class V hitch dragging the ground????
