Check Engine code PO 336
Old 09-03-2011, 05:24 PM
Slugblaster's Avatar
This code came up and read Crankshaft Pos Sensor Ackt Range Performance
Where is this sensor located and can I find it at my local auto parts because the dodge dealer is closed till tuesday. I was having a surge at around 40 mph and also sometimes when coming to a stop. One day the truck wouldnt start so I drained the water seperator on the air horn but when I opened the drain valve nothing came out but I could hear noise in the line coming from the tank and then the fuel started flowing.I let it flow for a couple minutes and the truck started right up and has since then but I got the check engine light
bentwings
0
06-29-2015 10:48 PM
horsehelper
02-22-2011 09:09 AM
deezul
10-29-2010 03:02 PM
KITCHEN
06-18-2007 09:31 PM
nojodas67
11-28-2005 10:46 PM
Quick Reply: Check Engine code PO 336
