Something very strange just happened......
I need a little help. I just drove my dodge to my shop to hook to the boat; when I turned it off, it didn't want to stop. I mean it didn't run like normal, but it sounded almost like it was trying to run on 1 cylinder or something. I couldn't choke it down by putting it in gear, but if I turned the key back on it just started to run again normally. It did this several times, so I pulled it back out into the yard. It shut off normally that time, so I cranked it probably 20 times in a row, with no problems. What's up with this???? Any info you guys can give is very much appreciated.
I did a search on starting problems and there was a lot mentioned about the starter contacts; I have been having an intermittent problem with the truck not turning over every so often, but the second try it works fine. Could the starter contacts have stuck?
Thanks for the info. I drove the truck to a fuel injection shop and talked to the owner there. He said he had not heard of one doing what mine dd, but if it were him he would start with the starter relay. It wasn't expensive and easy to change, so I replaced it. If that doesn't do it, I'll do the starter contacts next.
kelley15
Mar 23, 2006 07:45 PM
atch
Feb 23, 2006 08:07 AM
