Changing mirror heads..... Help
Old 12-16-2008, 08:13 PM
Urban Legend
bigfoot's Avatar
I have a cracked mirror on the right-hand side of the truck.
It’s a 02 3500 with the early (non electric) towing mirrors. I also have a 03 mirror (also non electric) that the mounting triangle is to big to use on my 02.
I know that everything else is the same. How do I change only the mirror head or the mirror head and arm?
If someone could show some pictures it would help a lot.
Old 12-16-2008, 08:22 PM
STate's Avatar
I think there is an access panel below the pivot point (to fold them in, not up and out) pull the access panel and there will be a nut. Loosen that and the rest should be self explanatory.
(I have not done this myself, only had it explained to me by a buddy)
Old 12-16-2008, 08:40 PM
Urban Legend
bigfoot's Avatar
Thanks I’ve looked at this, is it a nut or a keeper with a spring. I just don’t want to break it. Some good instructions would be helpful.
Old 12-17-2008, 09:19 PM
Urban Legend
bigfoot's Avatar
Well I looked around and found a tread on changing 03 mirrors over to fit an 02 .
Worked pretty well the biggest pain was compressing the spring, tying it off with wire and getting it to fit in place, other than that not a bad or hard job.
By the way if anyone in the DFW area needs mirrors try Cert-I-fit in Arlington TX.
Aftermarket 03 towing mirror (non power) $81.00
Old 12-18-2008, 07:48 PM
GUMP's Avatar
be careful, the spring is under a lot of tension!
jethroish
03-03-2014 10:09 PM
cj5er
12-20-2009 09:19 PM
capsparky111
02-05-2008 09:34 PM
Buzz
11-19-2002 09:49 PM
Quick Reply: Changing mirror heads..... Help
