Changing 6 Speed Fluid
Old 09-19-2005, 08:23 AM
Mark Hodowanec's Avatar
Changing the fluid on my NV5600. Is there a gasket to replace, or just put on some RTV. I want to pull off the PTO cover (& not just drop the lower bolt) so that I can clean the magnet
Old 09-19-2005, 08:32 AM
bulabula's Avatar
You can do either; what ever floats your boat. If you want a gasket, any NAPA carries the standard 6-bolt PTO cover gasket. They may ask you what thickness you want, but in the case of only wanting it for a cover, the thickness isn't important.
Old 09-19-2005, 04:54 PM
Jeff in TD's Avatar
I just did mine with redline. Shifts better while moving, but can still be tough to get into 1st when stopped.
I was surprised how much metal was on the magnet (photo in my gallery).
Stock, they are just sealed with RTV. Even with the PTO cover off, a fair amount of oil remains in the bottom, that you could pump out if you want.
jtrimmell
10-12-2007 09:26 PM
Original Junior
05-16-2005 04:04 PM
drecu
04-04-2003 08:28 AM
BradN
03-13-2003 07:32 AM
AFMSgt
19
02-04-2003 01:58 PM
Quick Reply: Changing 6 Speed Fluid
