change fuel filter
Old 02-19-2009, 05:16 PM
chrismegacab's Avatar
change fuel filter
Ok, the owner's manual says to change fuel filter about now.. I looked in the Fleetguard catalogue, and shows no filter for the 6.7
Do you have to replace the separator assembly??? Is it a drop-in type filter??
Thanks,
chris
Old 02-19-2009, 06:37 PM
Cummins610's Avatar
I believe its only available with MOPAR, you replace the entire assembly. Instructions come with the new filter, its a pain to remove/replace
Old 02-19-2009, 07:06 PM
sabersix's Avatar
FLEETGUARD FS43252E or MOPAR MOP5183410AA
Try Geno's Garage. It is a plastic screw in cartridge.
Only problem changing is that the fuel in the filter is difficult to drain so when you unscrew the filter and try to maneuver it out, it leaks and spills everywhere. ugh...
Old 02-20-2009, 01:13 AM
DaveB.inVa's Avatar
I don't have a 6.7 but when I'm changing the filter on my 5.9 I take a big gallon sized zip lock bag, open it up and stick it in an area near the filter. After draining the filter a bit I drop it in the bag so I don't get fuel everywhere.
Old 02-20-2009, 07:32 AM
TNTech's Avatar
The Fleetguard filter is FS43252. Some time in June you will be able to buy the new housing that lets you change the element and not the whole filter.
Old 02-20-2009, 01:01 PM
ya, it looks like a pain to get to. Dodge has the filter for $40, im guesssing it's the cartridge... i checked AutoZone yesterday, THEY CAN GET IT it's $73, and it's a FRAM....
Thanks for the idea with the ziploc, will save me alot of complaining from the other half..
chris
Old 02-20-2009, 02:23 PM
sabersix's Avatar
Fleetguard and Mopar at Geno's Garage are $28-$30.
Old 02-22-2009, 06:36 AM
AirGrabber's Avatar
Napa (wix) will be releasing a filter soon. Part number 3373. As of a few weeks ago the new number shows up but lists as not yet available.
Old 02-22-2009, 12:34 PM
dodgeram_dude's Avatar
The trick to draining the filter is to open the valve at the bottom of the filter about 3 or 4 turns. You'll be able to feel pretty much when you've opened it too much and the valve feels like it's going to come completely out... don't wanna do that. It'll start to drain a little bit this way. Then what you want to do is to unscrew the filter from the housing just a little.. an inch or less. This is let a little air into the system and will allow the filter to drain much better. The reason that these filter won't drain very well is that it's a closed system, meaning no air can get in so that they'll drain properly. Cracking the filter open from the housing helps this problem.
Old 02-25-2009, 11:55 AM
CS7470's Avatar
Fuel Filters
Check out http://www.fleetfilter.com/index.asp they have filters for the 6.7 Liter Cummings...I believe is Part number #33733 $7.83 each
Old 02-25-2009, 02:54 PM
Onelongshot's Avatar
Location: Columbia in the Communist State of Chicago (Illinois)
Nope don't have it listed.
Old 02-27-2009, 09:59 AM
litespeedrider's Avatar
Genos Garage
http://www.genosgarage.com/prodinfo....mber=FS43252_E
fleetguard is a coupler dollars cheaper than Mopar
jmccart
13
05-27-2009 09:45 PM
vegashd
07-15-2007 12:24 PM
Lunyfringe
01-10-2005 05:40 PM
doitl8r
06-04-2004 11:14 AM
XTOAK
17
08-23-2003 09:07 AM
Quick Reply: change fuel filter
