Can't Decided, your opinion is needed! ;-)
Ok, I have a 2002 Dodge CTD. I want to add more power, but I have a couple other threads going with ideas, but I want to keep them in one thread.
Like I said, I have some upgrades done, and I need your opinion as what should be done next. Its not my daily driver, however I still want it to be if it was needed.
So, what I have done is:
-AFE Stage 2 Intake
-Magnaflow 4" straight piped exhaust
-Edge COMP
-Banks Torque Converter
-BD Flex plate
-Banks High Ran intake elbow
-Banks waste gate mod kit
-IssPro gauges (Trans Temp, Exhaust Temp, Boost PSI)
What I'm looking to do on the next "wave" of upgrades are:
-Fuel Pressure Gauge (not sure which one though)
-Bosch 300HP injectors
-FASS fuel pump
-Exhaust manifold (not sure how much good that is actually going to do?)
-BD Valve Body
If you have any better suggestions please let me know. The turbo is producing about 26-29 PSI, depending on the gear and RPM @ WOT, and once the turbo is up, there is no smoke. I have the comp box turned up to 5, with the sub setting on 5, and that made a huge difference. I'm just not sure if the above upgrades are the right path for the next "wave".
http://youtube.com/watch?v=u7G0h5h-2sQ << recent video of the truck.
-AFE Stage 2 Intake
-Edge COMP
-BD Flex plate
-FASS fuel pump
-BD Valve Body
How much more power do you think the Smarty will add? I can't find on their website "roughly" how much more, it says on the 03-07's, but not on the 98.5-02.
You definately need a FP guage ASAP!!!!!!!!
then move the VB to #2 spot. Did you tap the comp yet?
The Smarty and comp stack will make your head spin and put a smile on your face for days.
Average is 50-60 hp! But Smarty is more about the timing and the low end response than just raw HP.
01 & 02 Manifolds are stronger than earlier ones. Unless you just want an after market manifold... I would not change it for power reasons.
And, as stated, you need the fuel pressure gauge yesterday!
Your headed for 450+ hp! Will the BD Valve Body hold that much...I don't know? Might be better choices.
I would do F-1 injectors over the Bosch. JMO.
http://www.f1diesel.com/
RJ
RJ
RJ
RJ
Last dyno I had, I pulled 316 with 33" tires on 4.10 gears. Simple math I figured (and this is fuzzy math at best) 316x20% = 379.2HP (the 20% is ROUGH figures for driveline loss).
Yup! But I would rearrange my list a bit! Always wise...just not instantly gratifying... to handle the support systems before adding fuel (ie. hp)
1-FP Gauge
2-Valve Body
3-Bigger Turbo
4-FASS
5-Injectors
6-Smarty
JMO - RJ
1-FP Gauge
2-Valve Body
3-Bigger Turbo
4-FASS
5-Injectors
6-Smarty
JMO - RJ
I was referring to what RowJ said, move the Valve Body to #2 spot on your list before adding any more power to your truck.
the VB adds line pressure that the stock VB doesn't. Without a good one your gonna roast your tranny even with the Banks TC.
Totallyrad
09-20-2013 04:31 PM
Totallyrad
07-19-2011 07:41 AM
redneck2007
02-13-2008 10:53 AM
GBPB
05-10-2005 08:16 PM
