how can you know???
Old Nov 3, 2004 | 02:03 AM
nicholashang87's Avatar
Muted User
how can you know???
don't know if mine is a 410 or 373???
how can I get this info??
I have a 6speed...DRW QC
where can I look??
Old Nov 3, 2004 | 05:02 AM
eswartz's Avatar
I think there's a tag on the inside of the glove box lid.
Old Nov 3, 2004 | 06:28 AM
nonford's Avatar
Eswartz is correct! Just open your glove box and all your info from paint to axle ratio is there.
Old Nov 3, 2004 | 09:19 AM
FastZilla's Avatar
Usually there is a tag on one of the diff cover bolts that will have 3.73 or 4.10 on it...
Can't find out too much info on AAM. Could always spin a tire and count the driveshaft revs....
http://www.aam.com/technology/tech_prod_driveline.html
My glove box sticker kept peeling off. Pulled it off and stuck it inside the owner's manual....
Old Nov 3, 2004 | 11:13 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Tell us your RPM's while running in 6th gear at 70 mph and we can give you a pretty good guess about which one you have. A truck with 3.73 gears will run around 2150 RPM's at 70 mph....at least if memory serves me correctly.
Old Nov 4, 2004 | 02:14 PM
spudman's Avatar
3.73 at 70 is appx 2000rpm
Old Nov 4, 2004 | 02:45 PM
Prairie600's Avatar
Dually's always have smaller tires than SRW 2500's or 3500's - This messes with your final gear ratios slightly - might explain some of the differences?
Old Nov 4, 2004 | 03:55 PM
kry226's Avatar
Just check the glove box.
Old Nov 4, 2004 | 11:10 PM
J BODY's Avatar
I just plug in the vin and look at the options list on dealer connect........oh yeah! you guys can't do that
Old Nov 5, 2004 | 02:58 PM
thump93yj's Avatar
bingo... jack it up turn a tire one revolution... drive shaft will either turn 3.7 or 4.1 revolutions
or you could drop the diff cover and count ring an pinion gear teeth and divide then you'd be absolutely sure.
BIGOKIE
19
Jul 27, 2013 08:45 AM
Totallyrad
Jul 19, 2011 07:41 AM
JKM
Jul 3, 2005 04:59 PM
