Can wires for edge pyro get mixed up?
Old 01-26-2008, 03:56 PM
sallyman1's Avatar
Can you accidentally mix up the wires for the edge juice attitude. Some say my pyro readings are off. I think they were 2 seperate colors so i matched them up. would wires being mixed up throw pyro out?
If i cruise at 65 mph highway i get between 650 and 800 degrees celcius (is it celcius or fahrenheit on the attitude). When i punch it to floor and pass It QUICKLY reads 1300 ish but then BACKS OFF QUICKLY the instant i let foot off floor
Old 01-26-2008, 04:12 PM
txfiremedic's Avatar
I wouldn't think you could get the wires mixed up. You are right, they are color coded and it sounds like you're readings are correct. I run my Edge on lvl 1 and when I stomp on it, it will quickly jump up to 1350, where i have it set to back down. It will go over the 1350 some but not by far. As long as your not running that hot for a long stretch, 3-4 minutes, I think you will be fine, normally those hot bursts only last 10 seconds or so. Hope this helps
Old 01-26-2008, 04:19 PM
sallyman1's Avatar
I just started my truck. its -20 celcius out where i live. the egt read 280 and stays there until high idle kicks in. is this normal temp?
Old 01-26-2008, 04:25 PM
Sounds about right!
Old 01-26-2008, 05:59 PM
Billm2004's Avatar
DUDE! -20 C!! where in the heck do you live????? Thats way too cold!! sunny and 78* here in miami FL!! lol!
Old 01-27-2008, 08:12 PM
Big Smoky's Avatar
Sallyman, your readings are in Fahrenheit.
Old 01-27-2008, 09:15 PM
sallyman1's Avatar
the edge ones are yes.?
Old 01-28-2008, 01:26 PM
swampdiesel's Avatar
edge is in Farenheit, hey sallyman are you haveing any trans problems, or throwing any codes?
Old 01-29-2008, 09:33 PM
sallyman1's Avatar
no tranny codes or problems. no codes at all. to be honest truck seems strong. Could it be tranny slippage and then instantaneous bursts of egts?between shifts?
sallyman1
02-14-2008 07:24 PM
feveree40
10-03-2007 03:59 PM
Tommy93w350
04-19-2005 01:14 AM
TexasZach
21
02-12-2004 08:59 PM
Quick Reply: Can wires for edge pyro get mixed up?
