Can 12V's have the 53 block?
Old 11-23-2003, 12:55 PM
GO 4LO's Avatar
I'm hoping to go look at a '98 12V this weekend - is it possible for the late 12V's to have the 53 block? Thanks.
Chris
Old 11-23-2003, 01:11 PM
Jim Fulmer's Avatar
Re:Can 12V's have the 53 block?
Yes, I have one.
Jim
Old 11-23-2003, 01:13 PM
BBWD's Avatar
[quote author=Jim Fulmer link=board=16;threadid=22762;start=0#msg213085 date=1069614682]
Yes, I have one.
Jim
[/quote]
Jim: Where do you look to find the code? Thanks in advance
Old 11-23-2003, 01:14 PM
Dr. Evil's Avatar
Jim you're pushing 706/1350 on a #53??? WOW....really???
Old 11-23-2003, 01:16 PM
GO 4LO's Avatar
BBWD, I think you look under the injection pump to see if "53" is stamped into the block there. ?? Anybody have a pic of exactly where to look?
Chris
PourinDiesel's Avatar
You will find the embossed cast numbers on the front bottom of your engine block, right above the pan rail.
Old 11-23-2003, 01:21 PM
BBWD's Avatar
[quote author=PourinDiesel link=board=16;threadid=22762;start=0#msg213089 date=1069614988]
[/quote]
PourinDiesel:
Thanks for the info.
John (DH)
Old 11-23-2003, 04:34 PM
Jim Fulmer's Avatar
I wouldn't worry about it anyway but Piers has never had a problem with a 12V (53) I did talk to Van Haisley about it and he had changed 2 of those out with issues, told me mine should be fine now with the miles I have on it, it not like the 53's are prone to kicking a rod out, even if it did who could I blame except me being at this power level.......give me a little time and I'll try to push it higher.
Jim
Old 11-23-2003, 04:56 PM
Dr. Evil's Avatar
how about a 24V #53....any different???
Old 11-28-2003, 03:05 PM
Gymbo's Avatar
I have figured out that 98 12V's CAN be 53 blocks, but does anyone know if they ALL are? SOME are? A FEW are? Thanks
Jimbo
Old 11-28-2003, 03:16 PM
vtailflyer's Avatar
I have a 98 12V that is not a 53 block. I have about 4 small numbers where the 53 would be that are about 1/2" high. From what I understand this was the "mexican block" that had the thicker jackets still.
Old 12-01-2003, 10:45 PM
Barney's Avatar
Here is a picture of the 53 on my 98.5 ISB block. Look in the inspection mirror. I would think the casting series numbers on a 12V would be in the same place -- lower block area above the oil pan flange on the driver's side.
Old 12-02-2003, 12:09 AM
Dr. Evil's Avatar
Mines on the passenger side at the front - 2001 24V
Totallyrad
07-19-2011 07:41 AM
03CumminZ4X4
02-01-2008 11:15 PM
Bubspc
07-27-2007 10:32 PM
24Vford
01-02-2007 11:14 AM
Quick Reply: Can 12V's have the 53 block?
