Can 12V's have the 53 block?
Old Nov 23, 2003 | 12:55 PM
GO 4LO's Avatar
I'm hoping to go look at a '98 12V this weekend - is it possible for the late 12V's to have the 53 block? Thanks.
Chris
Old Nov 23, 2003 | 01:11 PM
Jim Fulmer's Avatar
Re:Can 12V's have the 53 block?
Yes, I have one.
Jim
Old Nov 23, 2003 | 01:13 PM
BBWD's Avatar
[quote author=Jim Fulmer link=board=16;threadid=22762;start=0#msg213085 date=1069614682]
Yes, I have one.
Jim
[/quote]
Jim: Where do you look to find the code? Thanks in advance
Old Nov 23, 2003 | 01:14 PM
Dr. Evil's Avatar
Jim you're pushing 706/1350 on a #53??? WOW....really???
Old Nov 23, 2003 | 01:16 PM
GO 4LO's Avatar
BBWD, I think you look under the injection pump to see if "53" is stamped into the block there. ?? Anybody have a pic of exactly where to look?
Chris
PourinDiesel's Avatar
You will find the embossed cast numbers on the front bottom of your engine block, right above the pan rail.
Old Nov 23, 2003 | 01:21 PM
BBWD's Avatar
[quote author=PourinDiesel link=board=16;threadid=22762;start=0#msg213089 date=1069614988]
[/quote]
PourinDiesel:
Thanks for the info.
John (DH)
Old Nov 23, 2003 | 04:34 PM
Jim Fulmer's Avatar
I wouldn't worry about it anyway but Piers has never had a problem with a 12V (53) I did talk to Van Haisley about it and he had changed 2 of those out with issues, told me mine should be fine now with the miles I have on it, it not like the 53's are prone to kicking a rod out, even if it did who could I blame except me being at this power level.......give me a little time and I'll try to push it higher.
Jim
Old Nov 23, 2003 | 04:56 PM
Dr. Evil's Avatar
how about a 24V #53....any different???
Old Nov 28, 2003 | 03:05 PM
Gymbo's Avatar
I have figured out that 98 12V's CAN be 53 blocks, but does anyone know if they ALL are? SOME are? A FEW are? Thanks
Jimbo
Old Nov 28, 2003 | 03:16 PM
vtailflyer's Avatar
I have a 98 12V that is not a 53 block. I have about 4 small numbers where the 53 would be that are about 1/2" high. From what I understand this was the "mexican block" that had the thicker jackets still.
Old Dec 1, 2003 | 10:45 PM
Barney's Avatar
Here is a picture of the 53 on my 98.5 ISB block. Look in the inspection mirror. I would think the casting series numbers on a 12V would be in the same place -- lower block area above the oil pan flange on the driver's side.
Old Dec 2, 2003 | 12:09 AM
Dr. Evil's Avatar
Mines on the passenger side at the front - 2001 24V
Totallyrad
Jul 19, 2011 07:41 AM
03CumminZ4X4
Feb 1, 2008 11:15 PM
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
