a/c problem
Old 06-24-2008, 04:11 PM
bangin6's Avatar
a/c problem
Does anybody have a heads up on the cause of why the lowest setting would not blow? My compressor cycles but no air movement on low. It works fine on every other fan setting.
TIA
Dan
Old 06-24-2008, 04:44 PM
Busboy's Avatar
Has to be the resistor block or broken wire close to the resistor if all the rest work. It could also be that the fan motor has tightened up and on low setting theres not enough power to move it. Spin the motor by hand to test.
Old 06-26-2008, 01:19 PM
justme-'s Avatar
Have you in fact verified the fan is not spinning on low?
Just because you don't feel air movement doesn't mean it's not moving air...
I don;t feel air movement on my 96 in low, but it works as it's supposed to.
CTD23
06-09-2006 09:32 PM
Checkmate
03-05-2005 08:36 PM
callum
11-21-2004 07:04 PM
dogman
12-27-2003 07:06 PM
Quick Reply: a/c problem
