Burnt fluid smell
Old Aug 29, 2009 | 03:30 PM
matrok's Avatar
Burnt fluid smell
Hello,
I have a 05' CTD 2500 w/ 46k. When I am at a stop light or sign, I can smell burnt oil or fuel (not sure which) coming through the vents and outside the truck.
The truck has oil on the cover plate that's behind the drain pan, but no stains in the driveway or parking lot. Oil was changed @ 45k and the levels were good prior to the oil change.
Any ideas? Should I take it in immediately or wait till the next oil change?
Thanks,
M
Old Aug 29, 2009 | 05:53 PM
1985cucv's Avatar
do you run rotella? cuz mine did it until i switched to a different oil
Old Aug 29, 2009 | 07:12 PM
Jeff in TD's Avatar
Is the oil level correct?
If high, you may have cracked an injector.
Old Aug 29, 2009 | 08:18 PM
CUM4X4MINS's Avatar
Any exhaust leaks?
Michael
Old Aug 29, 2009 | 10:12 PM
matrok's Avatar
1. I'm using Rotella 15w40. Oil Change every 5k miles.
2. Oil level is 1/4" above the safe mark on the dipstick. Truck hasn't been started for 5 hours. Oil pressure gauge on the dash reads normal (I know it's not that accurate) during idle and goes up when accelerating.
3. No known exhaust leaks.
I did smell the oil when I checked the dipstick and it definitely has the same smell I described originally.
Any further thoughts?
Old Aug 30, 2009 | 08:25 AM
1985cucv's Avatar
it is the rotella mine was like this too hated it
Old Aug 30, 2009 | 12:46 PM
CUM4X4MINS's Avatar
I use Rotella Syn and have never noticed any smell coming fdrom my vents...interesting. Good luck.
Michael
Old Aug 31, 2009 | 08:36 AM
Jeff in TD's Avatar
How's the seal at the back of the hood? The HVAC intake is in that cowl by the wipers.
Old Aug 31, 2009 | 09:33 AM
FunFinder5's Avatar
I have a different smell too for the first 1k or so after an oil change with Rotella T.
wrm
Dec 16, 2006 02:46 PM
eightball
Apr 6, 2006 08:30 PM
twhite
Jun 1, 2005 08:46 PM
G_T
Apr 18, 2005 07:22 PM
Mike D
Oct 4, 2004 04:45 PM
