btpassing the vss
Old 01-05-2010, 04:43 PM
disturbed24v's Avatar
btpassing the vss
i got under my truck and pulled the vss out.. i can spin the needle and there is a bunch ao rattleing, as i spinn the vss needle the other side do not turn . it spun just a second. then stoped,, what i am wondering.. is the wire and square needle that goes in to the vss will bypass it.. as it fits on transfercase just fine.. i hooked it back up to just hold it up out of the way.. was wondering if it would work or mess something up..
Old 01-05-2010, 06:05 PM
powerrammaster's Avatar
Connecting direct will throw off the speed. The little metal transfer case looking box is a gear box with a ratio. Do a search for "vss", there a re a bunch of threads including one in the sticky. I am in the same boat right now x2 trucks. The vss with a 2 wire plug is supposedly easily had at parts stores and is most likely to go bad first unless your square shouldered shaft or receiver is rounded or siezed.
bigrigger
06-08-2006 04:36 PM
mrwaters
03-14-2006 11:31 AM
auber
12-05-2005 01:36 PM
JMZ
04-05-2005 06:41 PM
Super4x4Duty
10-29-2004 07:46 AM
Quick Reply: btpassing the vss
