broke the timing pin.
I was barring the engine and pushing on the pin with a long bar and went too fast I guess and heard a snap and now I have no pin to find #1 TDC. will it hurt anything if the tip falls out while the engine is running? How do I find TDC to set my valves now?
The other way to do the valves is the "running mate" technique.
Basically cylinders 1-6, 2-5 and 3-4 come to TDC at the same time just on opposite cycles. So when 1 is at TDC compression, 6 is at TDC going from exhaust to intake stroke. You bar the engine until cylinder 6 exhaust valves just close and intakes open. You can hear/feel compression as you approach TDC. Then you set both intake and exhaust on 1. Then you follow the firing order of 1-5-3-6-2-4.
The pin is just plastic and will probably stay in the gear. shouldn't be a problem If it really concerns you it can be taken out by removing the holder and timing pin button and rotating to get it lined up to tug out.
I don't think I will try to remove the pin holder as it is too tight a fit for my hands to get in with a torx wrench and i don't feel like pulling the vac pump to do that so it will just have to stay. Thanks for your reply.
