Brake issue? I think...
Old 11-15-2010, 09:34 AM
mawghauler's Avatar
I'm looking for answers as to why my brakes seem to be engaged even though the e brake is off. The truck seems to react as normal in reverse, however, when I put it in drive there is a lot of resistance like the brake is on. This just started occurring since the cooler temps overnight. Any ideas from veteran 1st gen owners?
Old 11-15-2010, 09:58 AM
Onemoparnut's Avatar
Try loosening a bleeder screw and then tighten it back up then without touching the brakes see if the drag is still there. If it goes away you probably have a bad brake hose.
Old 11-15-2010, 11:28 AM
Busjoe's Avatar
jack up each wheel and see whats spinning and whats not. It could be a an issue with broken brake hardware, a froze up wheel cylinder, a stuck caliper, frozen e brake cable and more. when you are moving forward does it pull to one side or the other?
Old 11-16-2010, 12:34 AM
ofcmarc's Avatar
How are your wheel seals?
A leaky seal will coat the linings and swell them making the brakes grab.
Old 11-16-2010, 07:07 AM
KD93's Avatar
They might grab, but if they're coated in fluid are they going to actually do anything? No more friction if they're covered in oil, no? But, I've been known to be well wrong before. I'm thinking either a return spring isn't doing it's job, or there's a problem with the parking brake not releasing. The front pad is hanging up but the back pad is free, so in reverse the front pad isn't energising on the drum.
Old 11-16-2010, 07:17 AM
ofcmarc's Avatar
Oil soaked linings will grab.
Old 11-16-2010, 09:59 AM
maybe368's Avatar
x2...Mark
Old 11-16-2010, 10:32 AM
KD93's Avatar
Originally Posted by maybe368
x2...Mark
Good to know. Thanks guys!
Old 11-16-2010, 11:21 PM
ofcmarc's Avatar
Leaky wheel seals and icy roads are lots of fun.........
Old 11-17-2010, 06:39 AM
KD93's Avatar
I don't doubt it... Although, icy roads for 10 months of the year might get old after a while...
dan123dbl
02-13-2015 05:47 PM
cyawallac
11-01-2011 11:37 PM
nuhuskersfan1
06-25-2004 08:42 PM
DDysput
05-05-2004 07:44 AM
Quick Reply: Brake issue? I think...
